94+ intake manifold on a 93?
Old Apr 27, 2003 | 03:31 PM
DjArcadian's Avatar
Will an intake manifold from a 94+ LT1 work on a 93? More importantly can I just transport an intake manifold with fuel lines and injectors and put it on a 93 LT1?
Old Apr 27, 2003 | 03:46 PM
turbo_Z's Avatar
whats the point? i mean it would accomplish nothing really. also you might have problems hooking up the fuel lines since on a 93 as you know they attach on the left side where on a 94+ they attach at the rear of the intake by the EGR valve.
Old Apr 27, 2003 | 03:47 PM
DjArcadian's Avatar
My fuel lines are leaking on the rear of the manifold and I have the intake manifold leak as well. I figured you can usually score a whole used manifold cheaper than going to a dealer and buying the parts.
If the fuel lines connect differentally I'm just going to try and get a '93 one.
Old Apr 27, 2003 | 04:28 PM
Dr.Mudge's Avatar
If the fuel lines are leaking its probably the fuel line connection is it not? In that case I'd spend the $45 for a new fuel line, PITA to swap but, I am guessing the plastic is at fault not an aluminum rail.
The little clips inside my connectors became bent at one time but still work, they require a bit more labor in removing them without inducing further damage, oops.
Old Apr 27, 2003 | 04:37 PM
DjArcadian's Avatar
The connections are fine. On a '93 they're located near the front and I've looked at them and smelled them. No gas around the connections.
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
