Slight tick from new CC pro-magnum rockers. Anything to worry about?
Old Apr 26, 2003 | 09:57 AM
95LT1Z28's Avatar
Finally got the car back together from my XE 224/230 cam install. The cam sounds awesome!!! Anyways, when I am driving if I listen as hard as I can I think I can slightly hear the rockers ticking. I have to listen real hard though to hear anything. Do the Pro-magnum rockers make a little more noise than the stockers or should I go another 1/4 turn and tighten them up some more?
Jeff
Old Apr 26, 2003 | 10:23 AM
NOMAD's Avatar
Cool
You might have then too tight cause mine make alot of noise
-Shannon
Old Apr 26, 2003 | 10:24 AM
gb95zconv's Avatar
Yes ...they are alittle noiser...they will quiten down a bit when you get a few hours on them.
Old Apr 26, 2003 | 10:29 AM
The are what I would call "clickety". There will be more noise than the stockers.
Old Apr 26, 2003 | 10:38 AM
turbo_Z's Avatar
mine make a kinda wild clicking sound that increases with RPM till my exhaust note over takes it. a click is normal but if the clack then you have a loose one.
Old Apr 26, 2003 | 11:26 AM
ba96ta's Avatar
I had one loosen up on me about a month ago (bad locks had to replace them). I could definitly hear a clacking from insde the car (no straighning to hear that). If you can barely hear them from inside the car that sound about right.
Old Apr 26, 2003 | 12:01 PM
Don 97 SS's Avatar
A slight "click" is good, a loud "clack" is bad
Old Apr 26, 2003 | 05:14 PM
Janny's Avatar
Mine have a very audible click from outside the car. Can't hear them inside. If you can't hear them outside, they are probably too tight. Mine were the first time I installed; it cost me time in the quarter.
magman
Apr 15, 2016 03:08 AM
WobblySausage
Oct 7, 2015 02:44 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
autoxr166
Sep 25, 2015 04:21 PM
