my car is acting weird, i dont know why
Old Apr 26, 2003 | 01:52 AM
melissaz28's Avatar
Question my car is acting weird, i dont know why
i was told by some people on Houston-F-Body.org to come ask you guys what could be my problem....
here goes.....my car is making me mad... when i was at a red light a few days/weeks ago, it tried to lurch forward, when it first did this i though that i just didnt have my foot on the brake well enough because i had just leaned back to tend to my screaming one year old cousin... anyhow, the second time it did it, i knew something was wrong,so i told my dad. then i drove it around as usual and at stop lights i put it into neutral (it doesnt do anything in neutral).
well, then it decided it wanted to act stupid when i was backing up too.it does the same thing in park and when i start to accelerate.
then i was letting my boyfriend chris and his friend joe look at it and joe temporarily fixed it by tightening the hose that connects the intake to the manifold. i am not getting a check engine light or anything. and i asked my friend greg, who at first thought it was the TPS, but then he told me it could be either of a few things:coil, opti, oxygen sensors, or plug wires...
i am not much a patient person and i like things to be done the first time around.. what would probably be the reason that my car is doing what it is.
thanks in advance,
-Melissa
( my friend told me it is mad at me cause i havent raced it in so long although i dont think that is the case)
oh yeah, i have a 1994 Z28, auto, with about 62,000 miles
Old Apr 26, 2003 | 02:43 AM
ChuckZ28's Avatar
is the car stock or does it have a cam in it? Because if it does have a cam it will tend to do that without a torque convertor. Other than that I would get your brakes checked out if the car runs fine.
Old Apr 26, 2003 | 06:20 PM
melissaz28's Avatar
my car is stock, i know it isnt the brakes, my dad and my boyfriend both checked that out...
-Melissa
Old Apr 26, 2003 | 06:25 PM
IllusionalTA's Avatar
-Melissa
That could be the problem... but on a more serious note.. is it doing this w/ the a/c or the defrost on? if so it could possibly be when the clutch realeases on the pump it steps the idle up a bit due to the load change and is in turn making the car move or lunge fwd.. Could this be a IAC issue?
Old Apr 26, 2003 | 06:27 PM
Rodrigues's Avatar
When it lurches forward, do your RPM's increase at all?
Old Apr 26, 2003 | 07:03 PM
rage366's Avatar
hmmm, is your master cylinder working alright?
Old Apr 26, 2003 | 08:01 PM
mycarisfasterthanyours's Avatar
Does the RPM suddenly rise as well? If not, I give another vote for brakes. I know when mine was an auto, I had to clamp the brakes, especially when cold to keep the car from moving forward. If the brakes are fine, I would look into IAC. I doubt your coil, opti, oxygen sensors, or plug wires are causing any of this.
Old Apr 27, 2003 | 11:44 AM
melissaz28's Avatar
yes, the rpms go up.... it isnt the brakes because it does the same thing in park, and reverse, even if i dont have my foot on the brakes.
and my master cylinder is working.
thanks
-Melissa
Old Apr 27, 2003 | 12:01 PM
rage366's Avatar
if ur rpm goes high enough, it might be the reason.
as far as ur o2 sensor...opti...those are not the prolem...
Old Apr 27, 2003 | 12:11 PM
melissaz28's Avatar
what might be the reason?
Old Apr 27, 2003 | 12:18 PM
I would look into your IAC or you might possibly have a leak on your intake manifold somewhere. Stuff like this is usually pretty hard to diagnose without a scanner.
Old Apr 27, 2003 | 12:20 PM
melissaz28's Avatar
ok, i guess im going to get it scanned tomorrow, i dont think many places are open on sundays...
ill tell you guys what it says.
Old Apr 27, 2003 | 12:23 PM
rage366's Avatar
personally, i think u should take it to a diagnostic machine. if it's eletrical, then it'll show up...even if u dont have an ses light, it doesnt automatically mean everything's alright.
if it's not electrical, then it's a brake problem (low brake line pressure malfunctioning master cylinder), or, your high rpm's are overpowering your brake pads, or, ya just need new pads!
Old Apr 27, 2003 | 12:27 PM
melissaz28's Avatar
its not the brakes, my dad and my boyfriend both went over all that stuff... ill go out there in a few minutes and look at them. i know it isnt the brakes.
like i said a second ago, im going tomorrow to get it scanned. it hasnt really been doing it much lately. maybe my car is just pmsing
Old Apr 27, 2003 | 12:52 PM
ttuz's Avatar
yup
My z is doing the same thing when I first start it sometimes. Once it warms up no problem. By the way what is a IAC?
