Help! Rattling sound from procharger p1sc at idle?
Old Apr 25, 2003 | 07:21 PM
PinkShirt's Avatar
I have a strange problem. I just installed a 5# procharger kit on my 2000 WS6. When the car is idling, I get a metal on metal vibration sound. I put the car up in the air, and I can feel the vibration on the blower itself. It definitely seems to be localized there. What is puzzling me is that when I rev the car, the noise seems to disappear. I double checked the setup and the belt is rock solid, and everything seems to be securely mounted. Anyone have any thoughts on this?
Doug
Old Apr 25, 2003 | 07:53 PM
t-trimz28's Avatar
Doug,
Did you buy the kit new?
The blower will make alot of noise at idle. I've got a Vortech, and it makes the same "grinding" sound while idling. As long as your sure it's being lubed, it's fine.
Old Apr 25, 2003 | 10:57 PM
PinkShirt's Avatar
Yeah, I bought the kit brand new. I just can't imagine this kind of noise being normal. The other prochargers I've heard don't do it......
Old Apr 26, 2003 | 12:04 AM
pat95formula's Avatar
Doug you read my mind...
Doug,
we must be thinking alike...must be all the trees in our area... And it is getting lubed its a self contained unit. and yes we added the oil.........If anyone has anything it would be greatly appreciated...don't wanna see my buddy rip it out of the car and throw it!!!!!!
Old Apr 27, 2003 | 04:05 PM
CRZYTRN-92Z28's Avatar
sounds like an install problem. You got the procharger label facing flat and upright? I had to turn the actual procharger unit to get my label to sit the way they wanted it. Had a similar noise until I flipped it correctly. GL
Old Apr 27, 2003 | 06:27 PM
ToddR's Avatar
Check the supercharger pulley mounting bolt and make sure it is tight. Mine started having a very loud "rattle" at idle and this was the problem. Thought my bearings were going bad. Might be worth checkin.
Old Apr 29, 2003 | 01:35 PM
Luna's Avatar
Re: Help! Rattling sound from procharger p1sc at idle?
Doug
This will occur on the LT1 kits if you don't grind enough material away from the ABS mount. Maybe this will be a similar deal on the LS1. Under load the engine rotates in the mounts. All is well except under non load conditions.
Old May 4, 2003 | 04:08 AM
96 WS6's Avatar
TTT, I'm curious... I have this same sound at idle-1500 rpm usually only when i'm not accelerating. To tighten the pulley do you just tighten it with the belt on? I don't see any other way... Anybody else have experience with this problem???
Old Jul 19, 2004 | 01:24 PM
TenaciousDB's Avatar
Old thread, but I figured I'd add to it.
According to ATI it is perfectly normal to hear a sort of rattling sound from a P-1SC at idle. It can and often does make this noise at idle similar to what I would consider "marbles rattling inside it". The noise should go away immediately when you give a little gas and rev the engine out of idle. If you're experiencing this, you probably have nothing to worry about. If the noise continues at other RPMs, then you may have other problems. Make sure you added the proper amount of oil (which is a no brainer--add the whole 6 oz. bottle to an empty P-1SC). If you still have concerns, I would urge you to call ATI at 913-338-2886 and ask to speak to a technician and explain what you're hearing. Have your serial number handy (off the blue tag on the blower).
Dave
Old Jul 19, 2004 | 10:57 PM
Ed Blown Vert's Avatar
If it sounds like marbles, that is normal for a new Procharger. Mine used to do the same.
Old Jul 22, 2004 | 07:11 AM
SloLt1Z's Avatar
Mine did it when the tensioner pulley was starting to go.
D1SC383LT4
Jan 1, 2016 01:56 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
