got some $$$, what should i do?? (cam people inside)
Old Apr 25, 2003 | 10:49 AM
Jackse's Avatar
I'm thinking about putting a bigger cam in my car. With the mods in my sig. what do you think i should go with? it the lt4 hot cam kit any good or should i go with a comp? thanks! btw, i would get the pcm reprogrammed to match up with the cam.
Old Apr 25, 2003 | 11:00 AM
LimitedEd1LE's Avatar
If you plan on porting and polishing your heads then I would get a cam other than the Hot cam. If you are tight on money the Hot cam is great, but there are many more out there. Check out www.cmotorsports.com I just got the XE 224/230 and I love it. Great pull midrange and up. Another thing, do you have to pass emissions?
Old Apr 25, 2003 | 11:34 AM
Derrick Redd's Avatar
I've seen people with ported and stock heads making good power with the XE 230/236.
Old Apr 25, 2003 | 11:49 AM
jonaddis84's Avatar
Definitely go with any of the Comp XE grinds, or get a custom grind from Combination motorsports, assuming that you dont have to pass emissions. Get the package from combination too, its a great package from what Ive heard, and you dont have to machine the heads for the springs.
Old Apr 25, 2003 | 12:00 PM
ShelbyZ28's Avatar
I would go with a Comp XE cam like said above. I'm planning on either the 224/230 or 224/236 for my car. I'm going to keep the heads stock for now. Go through www.cmotorsports.com and get their cam kit. Its an awesome deal
Bryan
cmsmith
Mar 16, 2015 02:34 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Queens94z28
Dec 20, 2014 09:11 PM
Z28Wilson
Aug 1, 2002 04:27 PM
