Any way to adjust idle?
Old Apr 24, 2003 | 07:22 PM
ChrisJ325's Avatar
Question Any way to adjust idle?
Is there anyway to adjust idle without having to send my PCM off and have it changed? I just installed a cam and it idles around 1000 on the tach, and it was idling lower but after driving it around today, the idle has went up to 1000 and the cam isnt as noticeable at idle... I was hoping there is a way to adjust it to idle lower so I can hear the cam more Is there a way to do it?
Old Apr 24, 2003 | 08:04 PM
BOWTYDE's Avatar
No, the idel is fixed and is controled by a motor of some kind. You can program it with FreeScan.
Old Apr 24, 2003 | 08:24 PM
Brent94Z's Avatar
Super Moderator
1000 is higher than the stock idle. If the idle hasn't been changed in the PCM, you have a problem Take a look at your throttle body and see if you can adjust it down with the set screw. Your IAC could be "stuck" maybe causing the high idle or you might even have a vacuum leak. How does the car run?
EDIT: Your tach could also be off. Is the idle higher than it was before the cam install?
Old Apr 24, 2003 | 08:55 PM
Curt (pres AAMC & ZAA)'s Avatar
No you can't.
Old Apr 24, 2003 | 09:15 PM
xxsaint69x's Avatar
hmm i think i have the same problem..i am goin to make sure tomorrow......I looked into my LT1 edit file on the computer and it says that my idle is set at 700 but scanmaster says 950 hmmm...maybe i have wrong file uploaded to PCM..Ill check that tomorrow....WHAT IF it is 700 in the PCM but it reads 250 higher?!!
Car runs great
Old Apr 24, 2003 | 09:34 PM
VKasm1's Avatar
I always thought that 1000 ( in nuetral ) was normal for our cars. M6
Old Apr 25, 2003 | 01:00 AM
Dr.Mudge's Avatar
No, stock idle for an M6 is 800 RPM, however the tach is innacurate.
Old Apr 25, 2003 | 01:04 AM
smokindastangs's Avatar
mine has always idled at 1000 as well. I hope it is a tach problem!
Old Apr 25, 2003 | 11:21 PM
alexis01's Avatar
mine idled at 1000 on the tach, but shows 800 on freescan...
Old Apr 26, 2003 | 07:45 AM
Don 97 SS's Avatar
A malfunctioning IAC or an air leak elsewhere can cause a high idle. Did you use fresh gaskets on the intake and TBI during the cam install? Is everything TQ'd properly?
Old Apr 26, 2003 | 09:39 AM
jonaddis84's Avatar
So if you adjust the set screw on the TB will the PCM compensate and keep the idle the same, I need to lower my idle too, I want it to idle at like 700 or so and its at like 850 now.
Old Apr 26, 2003 | 10:16 AM
gb95zconv's Avatar
Yeah, its a waste of time to look at the stock tach....read the pcm with some logging software.
Old Apr 26, 2003 | 10:49 AM
BPS's Avatar
BPS
If you adjust the set screw to close the blades the PCM will increase the IAC to compensate and hit your programed targets.
If you adjust the set screw to open the blades the PCM will lower the IAC (ie close it) to hit the programmed targets.
However, you can increase your idle past the programed amount as the PCM is limited in it's ability to reduce air - basically when the IAC is fully closed.
In a stock TB there is also what appears as a drilled air hole through the TB about 1/4" di. which lets air through without PCm control.
Your likely problem is a dirty IAC motor - take it out, spray with carb cleaner, be careful not to push ort pull the pindle and reinstall - this can be done on the car and does not require gaskets.
grgguy
17
Feb 23, 2015 07:57 PM
jb4xx
Feb 2, 2015 10:00 PM
edman
Jan 25, 2015 02:41 PM
A's 91 Z28
Jan 11, 2015 10:58 AM
