Best spring/shock combo for a street/strip car?
Old Apr 23, 2003 | 01:38 PM
snksknr94's Avatar
I'm currently running the pro-kit with factory shocks, but I'm intersted in changing to something that will help with launching at the track. I was thinking about going with the Hal QA1 shocks and springs, but I'm not sure how much they lower the car, etc. Anybody have any comments or reccomendations? I really want the car to squat good, but it is my daily driver so a strictly drag race shock is out of the question.
Old Apr 23, 2003 | 03:24 PM
RicocheT's Avatar
Was considering those same shocks for a buddy of mine. He has the same b4c car you have although it's an A4. He needs some traction also b/c of his new 383. He's also running the eibach's. I was thinking if I could get enough front end travel along with the rear squatting that i might be able to get his car down the track with a good amount of traction and be able to use the same spring.
Just considering and giving him some options b/c I believe he wants to dip down in the 12's.
Old Apr 23, 2003 | 04:00 PM
speedmiser's Avatar
The hals shouldnt lower the car at all. They have a height adjusment. I've got a front set with springs on order, partially for that reason...
Old Apr 23, 2003 | 04:24 PM
chesee48's Avatar
The HAL'S are amazing. You are right, they have the front height adjustment. But the back i think sits a tiny tiny bit lower then stock. I had the sportlines prior with the stock shocks and i couldnt even put my fingers on top of the tire b/c of the wheel well
But 12 way adj., u cant beat that. Definetly great set-up for the track and street IMO..
Old Apr 23, 2003 | 04:57 PM
Mikey97Z's Avatar
Question
I've got the Hal shocks all around, and the adjustable springs up front. The adjustability of the shocks is killer, and I lowered the front spring about an inch and it looks real nice. I want to lower the back one inch too, but I don't know what spring to choose because I don't want to hurt my launch too much. Does HAL make rear springs? What about the BMRs?
Old Apr 23, 2003 | 05:14 PM
chesee48's Avatar
Hal does not make rear springs. Thats why most use the stockers. But u could add your own aftermarket springs in the rear, but be careful...some may lower it too much ya know? Some advertised drop, is lower then what it claims once u get it on your car... But then again, if it doesnt look right, u can just adjust the front
Old Apr 23, 2003 | 06:27 PM
snksknr94's Avatar
I think the Hal's are what I'll go with. Now, to find a rear spring to go with them.
Old Apr 23, 2003 | 06:30 PM
chesee48's Avatar
stockers would work...just so u know
I used my stock springs..
Old Apr 23, 2003 | 10:02 PM
RicocheT's Avatar
Bmr says their springs have a 1" drop. I have considered these also
oldschool
Feb 9, 2016 09:21 PM
92ragtop
Dec 27, 2014 01:56 PM
MadMav
Dec 14, 2014 06:19 AM
USAirman93
Nov 24, 2014 03:37 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
