under drive pulley
Old Apr 22, 2003 | 09:23 PM
PentaVolvo's Avatar
under drive pulley
94 camaro 3.4 L auto
I am wanting to do a new pulley setup, but have a few questions. Is it just the one pulley that gets changed, or do the ones on the alternator, water pump, etc get changed? Are there any negative effects to doing new pulleys? How much is it goin to run me, and where can i find a new setup
thanks
Old Apr 23, 2003 | 01:18 AM
blue95's Avatar
The only real negative affect(or is it effect can't remember) to doing the pulleys is you can't really run a high end stereo system. Depends on your setup but it takes a little bit of power away from the alternator and sends it to the crank when you accelerate. Good for low end power.
Run about $50 if I can remember right....
Old Apr 23, 2003 | 03:47 PM
MustangEater82's Avatar
If you can find them used I woudl say get them, I woudl not pay what it cost for them new, they do nto help that much.
Downfall, I had charging problems with the alt pulley on but jsut running the crank I have no trouble charging, I have differnet head unit and stock speakers. Others have had this problem, car will run fine jsut dip in the red, when you have headlights, AC, radio and wipers on. That is where I noticed it the most.
RUENUF
Mar 13, 2016 03:39 PM
jasonduaine
Mar 7, 2015 09:44 AM
IrocSS85
Jul 18, 2002 10:35 PM
