Tach wire??? for shift light???
Old Apr 22, 2003 | 07:16 PM
NHSZ28's Avatar
Hey, i have a raptor shift light and i was wondering how to install it on 1994 z i was wondering where the tach wire is??? also about the slp fan switch how do you install that on a 1994 z28 also where are the connectors to go into???? thanks
Old Apr 22, 2003 | 07:52 PM
DarkHorse's Avatar
Do you have the actual SLP switch? I believe from the pics that it just plugs in. If your wiring it yourself do a search for shoebox, I think there's a link on his site. The harness should be located near your hood strut and the wires are "H" and "J" splice in, ground and your set. Using a switch of course.
Old Apr 22, 2003 | 08:02 PM
http://web.camaross.com/forums/showt...hreadid=106665
Your SLP switch should just plug in and the connector is by the base of the hood strut.
Old Apr 22, 2003 | 10:11 PM
muraoka's Avatar
tach wire is white #13 on the red connector of the ecm.
mr28
Apr 20, 2016 05:44 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
mr28
Nov 23, 2014 11:11 AM
GigaMp3z
Feb 20, 2003 02:57 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
