Ported MAF ends...BAD?
Old Apr 22, 2003 | 02:49 PM
JasonD's Avatar
Admin Emeritus
Red face Ported MAF ends...BAD?
Hey, I just installed some MBA ported MAF ends. I installed them and didn't have time to drive it and haven't since.
Now I am reading that this mod may not be a good idea due to making the car run lean.
What can anyone tell me about this? Any other problems in doing this mod?
Old Apr 22, 2003 | 03:34 PM
V6toZ28's Avatar
I tried MAF ends, and all the AM MAFs ... some of the AM MAFs and MAF ends put me lean, added KR, cost me rwhp and ET ... the other AM MAFs sent me rich, cost me rwhp and ET.
Bottom line, for the '01s and '02s MAFs are a real crap shoot, more often bad than good.
Good Luck
Old Apr 22, 2003 | 03:35 PM
BigZ28's Avatar
Yes, ported ends could lean the car out. People are seeing gains because the ends are leaning out the A/F ratio and adding timing, so the gains are really from tuning changes and not airflow.
Brian
JasonD's Avatar
Admin Emeritus
Question
Should I not use them then?
Old Apr 22, 2003 | 03:39 PM
sleeperZragtop's Avatar
Use em, the computer will register the changes and you'll be fine, just make sure you use 94 octane fuel...so you don't get knock...come to think of it, reset your computer.....another issue that comes up is A4's.....ported MAF's will decrease the line pressure making slow shifts...but I think you have an M6....you have no problems
Good luck
Old Apr 22, 2003 | 03:40 PM
V6toZ28's Avatar
Unless you put it on a dyno and/or ATAP to know for sure what's happening, you're probably better off leaving your MAF alone ...
Old Apr 22, 2003 | 03:43 PM
BigZ28's Avatar
I would not use them.
When we tried a set on Trevor's car(02SS) he picked up 2* of timing at WOT, but gained no power because of the added KR.
Brian
Old Apr 22, 2003 | 03:44 PM
blacknight's Avatar
I would try them since 01-02's runs very rich from the factory and maybe you'll get lucky. My SLP helped a lot as far as sotp feel and my dyno numbers are good. I'm running very rich with them not lean. If you install them it will take at least 100 miles before the pcm fully relearns the new A/f with them. Then the car will either run better or worse. If you get no pinging then you might be alright.
Old Apr 22, 2003 | 03:49 PM
Brian
Brian... to you guys....have a look what you guys done to me...check out the pics (noitce the sticker on the gas tank), I'll phoning Trevor for some truck heads very soon
Mike
Old Apr 22, 2003 | 05:10 PM
BlackNotchLX's Avatar
Brian
i just bough a $349 package from your company
85mm lid, holley air filter, elbow, 85mm mass air
am i getting the whole mass air replacement....and it's not this mod here that you're saying to not use right?
this is for a '98 T/A
Old Apr 22, 2003 | 05:37 PM
BigZ28's Avatar
The 85mm MAF is calibrated, so it's alright to use. The computer can adjust for the changes. When you add a set of ported ends, the MAF is not calibrated for the changes and that's when you run into problems.
sleeperZragtop- Nice!!
Brian
colts0455
Sep 2, 2015 12:41 PM
bunker
Aug 31, 2015 01:46 PM
bunker
Aug 21, 2015 10:21 AM
bunker
Aug 1, 2015 09:47 PM
