About removing cylinder heads
Old Apr 22, 2003 | 09:59 AM
PoorMan's Avatar
Milling head to raise compression??
Well, the mod monster got a hold of me pretty good. I went ahead and took the heads off to have them ported, larger valves, ect. I know the heads will be getting milled but what about the block. I am all most scared to go put a straight edge on it. What are the deck tolerances on an LT1 with aluminium heads anyway?
I am going to die if the block needs milling.
Jeff D.
Old Apr 22, 2003 | 01:29 PM
Z28SORR's Avatar
If you have not over heated your engine you should not need to mill either your block or your heads. Clean them and check with a straight edge. Milling the heads often causes problems with intake and exhaust alignment. Don't do it if you don't have to.
Old Apr 23, 2003 | 01:14 PM
PoorMan's Avatar
Thxs for the reply
I heard that you should mill the intake side of the head when you have the deck milled. Anyone know what milling 0.010, 0.020, and 0.030 off the head raises the compression ratio too?
This being with a stock bottom end, LT1 heads, and Felpro gaskets.
Jeff D.
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
Elcojoe
Nov 17, 2014 10:27 PM
