Help........please.....now
Old Apr 22, 2003 | 12:00 AM
stik6shift98's Avatar
Unhappy Help........please.....now
MODERATORS PLEASE DONT MOVE THIS!!!!!!
i have come to accept the fact my bottom end is gone.....
oil pressure low at 20
knocking coming from the bottom end like a ****
this was after doing heads and cam and ls6 intake and new oil pump.....
how much will this cost to fix? time to get a stroker?
WHAT WOULD YOU DO IF YOU WERE IN MY SHOES.....thanks
Old Apr 22, 2003 | 03:21 AM
SStrokerAce's Avatar
I'd look at getting a new LS6 short block from GM or a new forged short block from someone like ARE,MTI,LPE etc. You could go with a stroker but they are never cheap.
My personal choice on my LS1 is a built bottom end with a stock crank with forged rods and pistons. TEA 5.3L heads or some well ported 6.0L or LS6 castings.
Why did you go to the new oil pump? Sounds to me that something got into the system, like dirt or the oil pump was not installed right.
Either way sorry for the loss.
Bret
Old Apr 22, 2003 | 06:35 AM
Re: Help........please.....now
I feel your pain, but you are on the wrong forum.... these people build exotic engines and debate theoretical and practical performance limits. Not a lot of them who rebuild LS1's and they are not a pricing service. I can't see why this wouldn't work a lot better if you asked the hundreds of people who actually own LS1's and who do a lot of work on them.
Moving to LS1 Tech......
Old Apr 22, 2003 | 07:12 AM
u8dusst's Avatar
If I had a nickel for every thread that is moved out of advanced tech, id be a rich man.
http://www.ls1tech.com/ubb/ultimateb...;f=10;t=001884
Old Apr 22, 2003 | 02:39 PM
Re: Re: Help........please.....now
nooooooo
i wanted to get a responce from the advanced people because i might be getting stroked
maybe u could move it back PLEASE
Old Apr 22, 2003 | 03:30 PM
95GRNZ's Avatar
Probably not advanced enough questions to be in the Advanced Tech...
Cost? Depends how deep your pockets are, but I'm sure you can count at least $5K +/- something. Depending how far you want to go with it. If you just want to replace the short block, I'm sure you can get do that even cheaper.
Stroker? Sure. Depends on your pockts again.
TS
Old Apr 22, 2003 | 03:43 PM
sleeperZragtop's Avatar
DID YOU REPLACE THE TIMING CHAIN DURING YOUR SWAPS? THAT COULD BE CAUSING A PROBLEM...it is recommened that you replace the chain with a double roller forged chain...insurance my friend...the spray is hard on your bottom end as well
Good luck
Old Apr 22, 2003 | 03:46 PM
...there is nothng wrong with the 346ci...just get a rebuild with juice pistins and rings....forged crank and you'll be fine....many guys are running mid 10's on a 346ci
Old Apr 22, 2003 | 04:12 PM
After reading you other thread regarding ths issue...it makes me even more think your timming chain is hooped...your running low oil pressure...your oil pump runs of your timming chain...take it back to LS1speed and throw it in there face
Old Apr 22, 2003 | 04:15 PM
Good luck
i have the slp double roller timing chain
Old Apr 22, 2003 | 04:17 PM
but im getting knock.......
Old Apr 22, 2003 | 04:52 PM
96Z28/93TA's Avatar
is your engine oil really aereated? (lots of bubbles on dipstick) we have had a couple of this engines come in with a cut on the oil pump seal. the oil pump sucks in air and oil and your engine has low oil pressure and knocks as you stated. I would check that before anything ....btw I work at a chevrolet dealer
Old Apr 22, 2003 | 04:55 PM
i checked that.....no air bubbles
Old Apr 22, 2003 | 09:00 PM
...oh no I think your bearings are gone.....
Old Apr 22, 2003 | 09:07 PM
ya at speed inc they told me my bottom end is gone
ls1
