Help emergency car wont start
Old Apr 21, 2003 | 10:59 PM
zuluman13's Avatar
I washed the engine of my car after many people told me it was safe including a mechanic i didnt like the idea but i did and now my car wont start someone please help. TIA
Old Apr 21, 2003 | 11:07 PM
viperkiller's Avatar
let it dry and try to start it later shouldnt take to long
probably got the ignition wet i wouldnt worry unless it wont start after you let it sit
its not good to spray water on electrical the water let the magic smoke out of the components the magic smoke is what runs the car
Old Apr 21, 2003 | 11:10 PM
zuluman13's Avatar
I washed it this morning at 9 so it should of had plenty of time to dry I got it started once and it was very very rough and the idle kept going really low then back up but the whole car was shaking and after 30 min i tried to move it up the driveway because it was sticking halfway into the street and it stalled im afraid i really f###ed something up,.
Old Apr 21, 2003 | 11:14 PM
caliking97's Avatar
did the same thing at the car wash, needed new optispark
Old Apr 21, 2003 | 11:17 PM
It can take days to dry (if it even will). It is not recommended to spray water on the distributor (most often called optispark). Pray that it will dry out and you can delay in having to get a new one ($300 at the cheapest and you do the work yourself).
Now you know all those people you talked to were mistaken.
smokindastangs's Avatar
I aggree w/ the assumption that you got your opti wet and it messed it up.
Old Apr 21, 2003 | 11:18 PM
zuluman13's Avatar
How much is it to get done and is it possible to do it myself. Isnt there a vented optispark thats stronger? Also what is an optispark ive never heard of one besides on here.
Old Apr 21, 2003 | 11:31 PM
the optispark is gm's version of a distriubitor....there is a vented opti, however i believe that you have to change out several things; not just the opti.
Old Apr 21, 2003 | 11:34 PM
zuluman13's Avatar
what else would i need to change
Noenav
Mar 1, 2019 07:38 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Dave19yz28
Jan 26, 2003 01:45 PM
teedoff59
Aug 8, 2002 01:36 AM
