Can fuel pressure be adjusted with programing???
Old Apr 21, 2003 | 06:14 PM
BOWTYDE's Avatar
Can it, or do I have to buy a regulator?
I noticed on ws6.com that they dynoed 10 RWHP if a adjustable fuel pressure, how would I know what to set the pressure to if I bought one?
Old Apr 21, 2003 | 06:16 PM
Grease's Avatar
No you'll need an AFPR to adjust your fuel pressure. However on your car the 10rwhp you'll gain won't be for very long. but if you do buy one, you'll need to hook up a fuel pressure guage to your fuel rail to know exactly where you are setting it.
Old Apr 21, 2003 | 06:30 PM
BOWTYDE's Avatar
I did read that the computer changes once it realizes the pressure was changed. But if I were to have to car programed with PCMforless would I keep the gain?
Old Apr 21, 2003 | 06:33 PM
The learning function of the computer would still be active in closed loop, so the same thing would happen with anyone's programming.
Old Apr 21, 2003 | 06:34 PM
BOWTYDE's Avatar
So the regulator is pointless, unless I set the pressure and run the car, then reset/reprogram the PCM?
Old Apr 21, 2003 | 06:48 PM
I am not an expert on fuel pressure, but my understanding is that you really don't need any change to stock pressures unless you have changed something in the fuel delivery system (like larger injectors) and have other mods so that your engine is capable of appreciably higher a/f flow.
By virtue of the O2 sensors, the pcm will soon learn what pulsewidth to use to keep the a/f ratio at programmed levels.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
