427 ls1...
Old Apr 20, 2003 | 07:08 PM
vz125dude's Avatar
427 ls1...
can a standard ls1 engine be bored out to 427 ci??? and how much would it cost?
Old Apr 20, 2003 | 07:28 PM
Black6SpdTA's Avatar
doubt it, w/o strokin it you'd be lookin at approx. 4.422" bore if i did the math correctly
Old Apr 20, 2003 | 08:12 PM
Z28x's Avatar
No, the 427 LS1s are based off of the C5R race block.
Old Apr 20, 2003 | 08:24 PM
vz125dude's Avatar
whats the difference between the ls1 block and the c5r block?
Old Apr 21, 2003 | 12:18 AM
2002Z28SSConv's Avatar
Just about everything.
Longer stroke, wider bore obviously. They probably add more structural support and different this and that's.
It probably still bolts up to everything due to external dimensions being the same. But everything inside is gonna be changed.
Old Apr 21, 2003 | 12:38 AM
stik6shift98's Avatar
whats the largest you can bore out and ls1? and how much to expect for everything involved?
Old May 5, 2003 | 11:12 PM
Z28x's Avatar
I believe 382 or 383 is the biggest size an LS1 can be bored out to.
Old May 5, 2003 | 11:20 PM
i was preety sure it was 382
Old May 6, 2003 | 01:13 AM
Aklaim's Avatar
Boring and stroking are two completetly different things. You cannot bore a LS1 to 383 or 382. You can stroke an LS1 to 382, but you cannot bore it.
Old May 6, 2003 | 06:56 AM
PhantomTA's Avatar
Moderator
you can go over 382 with an all bore motor with the right sleeves..
you have to resleeve and ls1 to bore it.
all of the big motors are strokers.. however the only one to use the stock bore is the 382
Old May 6, 2003 | 07:08 AM
CPFarhood's Avatar
MTI does a 387 Bore but i've never heard of anything larger than that. Not on a factory LS1/6 Block
Old May 6, 2003 | 07:27 AM
94BlackBowtie's Avatar
Aluminum 427's are...king. Act now and for only the retail of your car (not exactly, but close enough), you can have one of these beasts.
Old May 6, 2003 | 08:15 AM
CPFarhood's Avatar
Thats a stroke and a bore, the question was bore.
Old May 6, 2003 | 09:18 AM
I was just showing him what the 427ci was.
Didn't say it wasn't stroke and bore...
Old May 6, 2003 | 09:56 AM
SSCamaro99_3's Avatar
Must have........
