programming for 3200 stall
Old Apr 19, 2003 | 03:23 PM
AmmoZ's Avatar
I have a 2000 Z28 with an a4 , vig 3200 stall and wondering what kinds of things you have changed with LS1 edit for the stall and if you changed the shift firmness. Thanks for any info
Old Apr 22, 2003 | 02:49 PM
brokenz's Avatar
If you go here http://www.cardomain.com/member_page...page_id=336815 and look at page 3, change number 14, this is all I had to do too get the shift feel back to stock. I only changed values below 87.5% because above that they were already maxed (90 with an LT1/4L60E). I have never seen the value of increasing the pressure above the max factory pressure on a transmission that their is nothing wrong with. Does yours feel real soft on the shifts now? I would recommend small changes. I did alot of experimenting with mine and found that small changes made alot of difference. I prefer that the normal shifts feel like a soft push when they occur, not a hard bang. That's what I'd recommend.
Old Apr 22, 2003 | 04:27 PM
AmmoZ's Avatar
thanks for the info.
Nayr
Mar 3, 2023 08:34 PM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
MDZ28
11
Sep 24, 2015 09:15 AM
damnyankee36
Sep 9, 2015 07:06 PM
