Those that removed the splash guard inside
Old Apr 18, 2003 | 12:02 PM
SloMofo's Avatar
Lightbulb Those that removed the splash guard inside
Since my car no longer sees rain and such I was thinking of leaving off the splash guard under the car so my CAI could possibly function more efficiently.
I was just wondering if anyone has done this and actually seen any improvement and had any problems with the splash guard removed
Old Apr 18, 2003 | 12:06 PM
bradpreece95z28's Avatar
I removed mine and you can hear my cai sucking loud!@ although i have a 52mm tb and a maf. it sucks like a madman. i would think that it helps by recieving more airflow
Note: mine sees no rain either.
Old Apr 18, 2003 | 12:12 PM
94GrayV6's Avatar
Well, i had mine off on the V6 for about 5 months here in rainy flordia with no problems at all. I've had it off on the Z for a couple rainy days with no problems either.
Old Apr 18, 2003 | 12:21 PM
SloMofo's Avatar
Did either of you notice any gains at the track?
krispy's Avatar
i just took a razor and enlarged the plastic grates at the front of it
Old Apr 18, 2003 | 12:32 PM
MyTMous's Avatar
I just opened a big wedge shape in mine with a dremel tool so it sorta scoops the air into the hole.
Seems to work fine.
Working on a shield to protect the K&N filter so water doesn't hit it but not hurt the airflow.
Old Apr 18, 2003 | 12:37 PM
krispy's Avatar
just rig up a chicken wire shield and put plastic over part of it (where u can draw a line straight from the hole to the filter, so the air flows around it but the water gets deflected down, just use the chicken wire as a net and block off a specific portion, the wire wont effect anything, actually might block leaves/paper
Old Apr 18, 2003 | 12:39 PM
94GrayV6's Avatar
Well, i just removed them both when i installed the CAIs, so i have no basis for comparison of before and after results of removal.
Old Apr 18, 2003 | 03:53 PM
SloMofo's Avatar
Too much work for just that. car will not see rain as I said
Has anyone seen any gains at the track from doing this?
Old Apr 23, 2003 | 04:41 PM
SloMofo's Avatar
Still looking for more input
Old Apr 23, 2003 | 05:15 PM
Mikey97Z's Avatar
Thumbs down
I'll bet $50 there's no improvement.
Old Apr 23, 2003 | 05:24 PM
SloMofo's Avatar
I did not think there would be, but I want to find out for sure
Old Apr 23, 2003 | 05:38 PM
Derrick Redd's Avatar
I've had mine off for a year now. It makes the filter easy to remove at the track. I didn't feel a SOTP difference by just removing the shield, but it should be worth some hp by removing the filter at the track. JMO.
Old Apr 23, 2003 | 05:58 PM
SloMofo's Avatar
You're misunderstanding. I will not be yanking the filter. Just the splash guard!
Old Apr 23, 2003 | 06:37 PM
anaik's Avatar
I'll bet those grates are designed to push air up into the engine compartment. Also where your filter is.
