What is the motor mount
Old Apr 17, 2003 | 01:34 AM
Wildwill532's Avatar
What do I need Im on the passenger side LT's drivers side is in all the way but the passenger is stuck what needs to come off to raise the motor and do i have to do it to both sides and does it come from the top or the bottom to put in header
Old Apr 17, 2003 | 01:57 AM
HELP ME I NEED TO GET THIS DONE I HAVE TO WORK TOMORROW!
Old Apr 17, 2003 | 02:32 AM
Inutero's Avatar
get a floor jack, but a wooden block on it, and put it underneath the oil pan. Lift it and bring the enging up a few inches. Don't lift too high, you may damage the oil pan.
Old Apr 17, 2003 | 02:41 AM
I need to know how to do it though how to lift the engine all im doing is lifting the hwole car
Old Apr 17, 2003 | 02:50 AM
I took out all 6 bolts and my engine still doesnt move?
Old Apr 17, 2003 | 03:36 AM
Inutero's Avatar
I know it seems like your lifting the whole car, but trust me, your lifting only the engine mostly. I know it works the way I told you, I had to change a motor mount, and while we had the mount out, the floor jack was holding the engine up.
if it helps any, I will read to you exactly what my haynes manual says.
"Raise the vehicle and support it securely with jack stands. Place a floor jack with a wood block on the head of the jack under the oil pan and raise the engine slightly. caution: Don't apply too much pressure on the jack - the engine oil pan could be damaged.
hope this helps/
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
silvermansteve
Mar 4, 2015 05:02 PM
Nostang 96z
Aug 31, 2002 12:01 PM
