overheating 94
Old Apr 16, 2003 | 02:43 AM
jeff1586's Avatar
Angry overheating 94
Any suggestions on a overheating problem for a 94 z-28
My cooling fans come on but then they shutdown, I recall reading somewhere that someone wired there fans to run all the time is this true
Old Apr 16, 2003 | 02:47 AM
texasTA's Avatar
do a search for the "fan switch mod". This should give you some good info on how to do it. You can also have the PCM in your car programmed to have the fans on a lot sooner.
Old Apr 16, 2003 | 03:02 AM
1FASASZ's Avatar
try putting in a new 160 thermostat
Old Apr 16, 2003 | 03:07 AM
1FASASZ's Avatar
fan_switch
Old Apr 16, 2003 | 07:41 AM
94T56T-TOPDREAM's Avatar
I had the same problem. Put in a new thermostat, really easy to do and only about 5 bucks, and change your radiator cap(it actually does more than you think). THen if that doesn't work, pressure test it, you can get the pressure testing tool from a parts store that rents out tools. MOst will rent it fora depsoit that you get back. I Just re did my whole cooling system before I got mine to work. Everything from all new hoses(some of those are pretty expensive, I know one was $50 bucks) to a new radiator and water pump. Me and camaros keeping cool don't mix!!!
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
warmeck
Apr 16, 2015 05:50 PM
