what are the common ls1 problems?
Old Apr 14, 2003 | 09:06 PM
borden3's Avatar
i've had an lt1 for quite a while now and was looking into an ls1. what are the common problems with them? or any problems that you have had. lt1's have the opti, and oil leaks. thanks.
Old Apr 15, 2003 | 12:04 AM
norcalstreet's Avatar
Pushrods bending, piston slap, and rearend weakness.
Old Apr 15, 2003 | 01:56 AM
GoFast908Z's Avatar
Member
faulty water pump, belt tensioners, and belt squeak.
Old Apr 15, 2003 | 05:47 AM
TerrorDome's Avatar
piston slap, oil consumption for newer models, warped brake rotors, leaking pinion seal, slow passenger side power window,
i have leaking pinion seal but i replace my fluid yearly so it doesn't matter...very tiny leak.
the power window thing doesn't bother me at all.
Old Apr 15, 2003 | 07:17 AM
danziger's Avatar
Talking
Traction...
Old Apr 15, 2003 | 08:07 AM
KungFu's Avatar
I just had the rear pinion seal changed this week. Haven't had any squeeky belts yet. Rear driver side brake squeeks when I'm driving slowly though a neighborhood. Other than that and a dash board rattle I'm sitting pretty good.
Old Apr 15, 2003 | 09:05 AM
borden3's Avatar
sounds like almost all the same problems with my 97. other than the belts has anyone had any major problems with the engine?
Old Apr 17, 2003 | 02:17 PM
borden3's Avatar
any other problems?
Old Apr 17, 2003 | 03:24 PM
Ferocity02's Avatar
Leaky T-tops, T-tops that fly off on the freeway
Old Apr 17, 2003 | 06:17 PM
stik6shift98's Avatar
loves to eat oil
rotors warp like crazy
likes to do 360 in the snow and sometimes in the rain too
random oil pump failure and fuel pumps........
Old Apr 17, 2003 | 07:06 PM
u8dusst's Avatar
News flash. Just becuase a certain problem happens with YOUR car doesnt mean its common.
Old Apr 17, 2003 | 07:15 PM
TransAmLS1's Avatar
Originally posted by danziger
Traction...
LMAO!
Old Apr 17, 2003 | 07:50 PM
borden3's Avatar
seems like there are a lot less than the lt1's. thanks everyone.
Old Apr 17, 2003 | 07:55 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
03 cobra threads
Old Apr 17, 2003 | 08:03 PM
stik6shift00's Avatar
I have the slow window, $hitty gas milage...cause of mods and dirving...
AND of couse TRACTION but RWD is awesome most of the time!
