ok stupid question, but need help.
Old Apr 14, 2003 | 04:02 PM
scottslt1z28's Avatar
again like i said.....i might sound stupid, but i dont know how to do it. So can someone tell me how to flush out my coolant bay and clean it and then refill it again? Thanks
Scott
Old Apr 14, 2003 | 04:40 PM
z28Power's Avatar
You mean flush the coolant system, right?
It's fairly simple to get done.
1)There is a draincock on the bottom passenger side of the radiator. It's just a cheap plastic thing that you can untwist with a pair of pliers. Let all the coolant drain out into a bin of some sort.
2)To flush it, put the draincock back in, and fill the system up with 100% water and start the engine.
3)Let the engine reach operating temperature so that the thermo will open and let the pure water go through the system.
4)After it gets up to a decent temperature and has been running for a couple minutes, turn off the car and drain the water.
5) Repeat steps 1-4 until water comes out clean (it will take a couple)
6) Put draincock back in and this time fill with 50/50 mix of coolant and water until system is full.
7) Make sure you bleed the system via the two bleed valves on top of the hose going to the radiator and the one right on the thermo housing when you refill each time!!!!
Hope this helps!
Old Apr 14, 2003 | 05:34 PM
thanks.........thats exactly what i was wondering.....................what do you mean by bleed the 2 valves..........(how do you do this too)..........sorry for all the questions, im fairly new to doing stuff myself on my engine and am not familar with everything.......thanks
Scott
Old Apr 14, 2003 | 06:29 PM
ttt
Old Apr 14, 2003 | 06:58 PM
97silverz28's Avatar
Not saying this to insult you. If you're new to working on your car, you should go out & buy a Chilton manual for your car. It will help you out alot.
Old Apr 14, 2003 | 07:19 PM
well im about to sell it...........i bought the lt1 then i realized i could afford an ls1 so im going to sell it and buy an ls1.........i just am wanting to do this...........thanks
Scott
Magenta_Hearts
Mar 5, 2015 07:01 AM
Deadbolt24
Jan 19, 2015 01:29 PM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 15, 2014 03:09 PM
Hurin
Dec 13, 2014 07:38 PM
