installed moroso cai...now hood wont shut right
Old Apr 13, 2003 | 12:26 AM
MarkyMark's Avatar
Go
I installed my moroso CAI today, and it seemed to fit pretty good after some initial issues. When i went to close my hood though it wont shut unless i force it down kinda hard. Then when its shut the drivers side sticks up about 1/4 inch or so. I CANNOT get the moroso to go down any lower, i tried forever, but there is nowhere for it to go. What should i do? Anyone else have this problem?
________
Live Sex
Old Apr 13, 2003 | 01:05 AM
anaik's Avatar
The part that bolts to the body part in the well, you have it upside down. The long part goes into the well and the filter clamps to that.
Old Apr 13, 2003 | 02:04 AM
n2oCamaro's Avatar
It also helps if you mount the plate on the under side if the wheel well. Meaning instead of placing it on the hole from the top do it from the bottom. A little more PITA to install but gives you a little more clearance for the hood.
Old Apr 13, 2003 | 02:24 AM
97CamaroZ28R's Avatar
I had the same problem as you when installing my Moroso CAI. I installed it correctly, but it still made my hood sit high on the drivers side . I replaced my hood with a 3" cowl about a month later and it fixed the problem. My hood did not come with insulation. I suggest trimming the insulation around the CAI. If this does not help I reccomend n2oCamaro's fix. It should give you the clearance you need.
Old Apr 13, 2003 | 02:27 AM
Rich_z28's Avatar
I agree with the above post. I have the Lingenfleter CAI that is identical to the Moroso kit and my hood did the same thing. I ended up trimming the insulation where it looked like it was hitting on the intake tube and haven't had a problem with it since.
Old Apr 13, 2003 | 02:54 AM
anaik's Avatar
If installed correctly, nothing has to be trimmed. I have one.
Old Apr 13, 2003 | 07:43 AM
TedH's Avatar
Mine fit fine with no problems.
Old Apr 13, 2003 | 07:51 AM
Dan Oldham's Avatar
I've got the Moroso also, with no problems. It IS a tight fit, as I can see the rub marks on the intake where the hood has been resting, but I've had no problems with the hood closing or sticking up like you're explaining. Are you sure you have the intake pushed on as much as possible? Howbout that big rubber seal? Sure it's not bunched up or anything?
Old Apr 13, 2003 | 08:09 AM
lvkleinstiver's Avatar
I have a Moroso CAI and it fits fine. I installed it per the instructions and have no problem with hood clearance.
Old Apr 13, 2003 | 11:25 AM
MarkyMark's Avatar
Go
i did install the long piece down and i did the install correctly. I may trim some installation or try putting the plate on the bottom side i guess. Thanks for the help guys
________
Philippine girl live
jasonduaine
Mar 7, 2015 09:44 AM
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
fpete1992
Dec 11, 2014 03:51 PM
thenewkid
Nov 27, 2014 09:41 AM
