Anyone know the felpro part number for a full gasket set?
Old Apr 8, 2003 | 04:22 AM
ZZ's Avatar
ZZ
Question Anyone know the felpro part number for a full gasket set?
And if so, what does it cost on average for the LT1? I don't want to pay a lot for gaskets, so any alternatives are welcome. Thanks
Old Apr 8, 2003 | 05:22 PM
badass383's Avatar
The only kit I saw and ended up using was the Trick Flow kit from Summit part number TFS-31400911 and it contains all Fel-Pro gaskets.
It sells for $318.
Old Apr 8, 2003 | 05:43 PM
gelbza's Avatar
In the picture on the Summit website of the kit, there's two samll crooked gaskets, sitting inside the left valve cover gasket. Are these for the front and back of the intake manifold, and if so how well do they work?
Old Mar 27, 2004 | 11:57 PM
Dave88LX's Avatar
It sells for $318.
Holy Christ there's gotta be a cheaper way to do it!
Old Mar 28, 2004 | 08:21 AM
You don't use gaskets on the front and back. You use RTV. Earlier SBCs use gaskets.
Old Mar 28, 2004 | 08:30 AM
When I recently had my engine completely apart, I did not need a complete gasket set. I spent $116 on gaskets.
That included:
timing cover
oil pan
rear main and rear main housing
head
intake
water pump
exhaust manifold
Old Mar 28, 2004 | 12:47 PM
Dave88LX's Avatar
That included:
timing cover
oil pan
head
intake
water pump
exhaust manifold
Those are the only gaskets I need to do an ENTIRE rebuild on EVERYTHING with all new gaskets?
Throttle body...
3 seals that go into the timing cover
Old Mar 28, 2004 | 02:38 PM
Throttle body...
I did not need the TB or round timing seals. There really is not an excess amount of gaskets on this thing.
Old Mar 28, 2004 | 03:04 PM
Dave88LX's Avatar
I just spent ~ hr researching gasket sets that thunder and combo have, as well as making a chart, I've got a post here if you want to see it. What's a PITA is that a lot of sets are redundant with gaskets.
How are GM gaskets vs the Fel Pro's? I'll be using FP-1074's for sure.
I have to see about intake gaskets, since I'm going to be running ported heads, same with the exhaust gaskets since I've got Jet Hot Long tubes...
parkers Z28
Mar 11, 2016 08:14 PM
FirebirdGT
Dec 13, 2014 10:25 PM
Brandon Wittmer
Dec 8, 2014 07:53 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
