94 cam in 95 car... possible?
Old Apr 7, 2003 | 09:23 PM
Highlander's Avatar
Is it possible to install the 94 cam in a 95 style opti???
Old Apr 7, 2003 | 09:48 PM
You will need a longer dowel pin and the hole in the front of the cam enlarged to the the size in the the 95+ cam.
Old Apr 7, 2003 | 09:49 PM
Highlander's Avatar
So it can be done and a machine shop should be able to do it??
Old Apr 7, 2003 | 10:26 PM
Ponykillr's Avatar
I pulled the 94 pin out and went down to Home Depot and bought a metal rod cut it to size then tapped it into the cam. It works fine on my car. + Home Depot is a great place to buy Highperformance parts for cars if you have a imagination.
Old Apr 7, 2003 | 10:38 PM
Sure.
Old Apr 7, 2003 | 11:33 PM
Highlander's Avatar
All you need is the dowel pin?? that is it?? the center hole is no problem???
Let me know
Old Apr 7, 2003 | 11:56 PM
Ponykillr's Avatar
Pulling the old pin out of the 94 cam is a pain. All you need is a longer pin. like i said i just cut a rod from Home Depot and tapped into the 94 cam so it was long enough did it all myself for like $1
Old Apr 8, 2003 | 05:47 AM
Mtrhds94Z's Avatar
I agree with Rob that the cam would need a larger nose drilling[to fit the 95+ opti..]
Old Apr 8, 2003 | 06:51 AM
Javier97Z28's Avatar
Moderator
I believe I will have to lay down the question.. "why?"
Old Apr 8, 2003 | 08:04 AM
Why what?
Old Apr 8, 2003 | 08:11 AM
bigsteve7's Avatar
Why what?
v
I think he wants to know, why swap cams?
Old Apr 8, 2003 | 08:55 AM
Originally posted by bigsteve7
v
Charlie already explained why. That is why I said "why what?".
If you are going to use a vented opti, the front of the cam needs clearance for the part of the opti drive that protrudes. The non-vented optis don't have the protrusion and therefore the cams don't need the hole in them.
Cam used with vented opti on the left in this pic and cam for non-vented on the right.
Old Apr 10, 2003 | 02:28 AM
Zepher's Avatar
I just put my engine back together with the hot cam and the dowel pin was only sticking out maybe an 1/8th" or so from the cam gear.
Anyone have a picture of the pin sticking out from the cam gear?
My engine is a 95 Caprice LT1 with a 96 SS Opti and accessories.
I heard that the accessories won't line up due to the crank hub being a little longer on the Caprice, so I am going to look into that as well.
Old Apr 10, 2003 | 08:34 AM
Maybe this pic will give you some idea.
Old Apr 10, 2003 | 08:47 AM
Dr.Mudge's Avatar
You also need a 95 cam gear, drilling one of those could be done by a machine shop I'm sure, a hand drill wont do it in a reasonable time. Even if your getting a good deal on a used cam, I think you'd probably about break even on price here.
