New shifter install?
Old Apr 6, 2003 | 07:02 PM
95TA8280's Avatar
I was looking at adding The Ripper or some other aftermarket one....how hard is the install? What do I have to remove?
Old Apr 6, 2003 | 07:53 PM
MrZ's Avatar
MrZ
The install isn't that hard. All you have to do is remove the console. I had a hell of a time (mostly because I'm a moron) but there are only 3 or so screws and it comes right out. Installing the shifter itself is VERY easy. There are many guides on the net if you look around, a good one is at Project Trans-Am
Travis
Old Apr 6, 2003 | 08:05 PM
leadfoot94's Avatar
These are the instructions I got with my Ripper.
Step#1
Remove the ****, the boot and the trim plate from the stock shifter. Remove the plastic or leather handle portion of the parkig brake lever. Remove the screws that hold the console to the floor and instrument panel. Unplug the wiring to the cigarette lighter and glovebox light. Then remove the second rubber boot that is attached to the floorpan.
Step#2
Next you just remove the bolts holding the stock shifter in place, and pull it out.
Step#3
Then you just swap in the new one with the correct adjustments, and put it all back together the way it came off.
It's really easy to do, it took me like 30min or so, I goes quick once you actually see everyhthing that has to come off.
Old Apr 6, 2003 | 08:45 PM
95TA8280's Avatar
You glad you got The Ripper?
Old Apr 6, 2003 | 09:30 PM
1FASASZ's Avatar
when you take you council off put your e brake all the way up put the passenger seat all the way back the lift the council up and twist it out over the passenger seat and pull it over the e brake. thats how i got it out in my z i dont know how different a TA is
Old Apr 6, 2003 | 09:34 PM
CamaroBoy96Z28's Avatar
Its REALLY easy. I did it with my friend in the matter of an hour because some bolts are hard to get to. Ditto on the e-brake thing.
Old Apr 6, 2003 | 10:57 PM
96LT14u2Nv's Avatar
it is really easy, i did mine in about 20 min. u should have no problems with the install. it is pretty self-explanitory after u get the console off.
Old Apr 8, 2003 | 11:29 AM
leadfoot94's Avatar
Yes, I am very happy with the shorter shifts and the quality of the shifter itself, I have had no problems since it was installed almost 2 years ago. Really though, any shifter is pretty much better than the stock one.
Old Apr 8, 2003 | 11:34 AM
97Z-M6's Avatar
i agree, but no shifter is better than the pro 5.0 no not one.
Nov 18, 2023 07:21 PM
BigWil
Mar 29, 2015 12:24 PM
karpetcm
Feb 9, 2015 09:21 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
