a4 wont shift out of park
Old Apr 6, 2003 | 01:14 PM
worak's Avatar
Question a4 wont shift out of park
every once in awhile i cant get my car to shift out of park. i press the brake down and attempt to shift into drive, the thing sticks. ive taken the the console off and cleaned everything to see if that helped, but it still does it every so often. if i beat the **** out of it, it will shift to drive. any suggestions?
Old Apr 6, 2003 | 01:48 PM
Blk94Z28LT1's Avatar
check the mechanism that stops it from shifting out of park until you hit the brake pedal.
Old Apr 7, 2003 | 01:12 AM
worak's Avatar
ttt
Old Apr 7, 2003 | 10:17 AM
RENE95Z's Avatar
I have somewhat of a similar problem. First startup of the day, trying to press down the button to shift out of park is a bear. Sometimes I have to pound down on the button to "loosen" it. After that, pressing the button down throughout the rest of the day is not a problem. I don't know if this is due to dirt buildup since I haven't pulled off my console to find out. Maybe someone can enlighten us.
Old Apr 7, 2003 | 10:46 AM
My94RedZ28A4's Avatar
Agreed.
Old Apr 7, 2003 | 03:35 PM
TransAm219's Avatar
are you guys parking on steep hills ? Sometimes the trans seems to get in a bind if there is a lot of pressure on it
Old Apr 7, 2003 | 03:59 PM
TobyZ28's Avatar
I park on a hill every day and get a bit of a bind, just gotta pull a bit harder I spilt coke on the cover tho so it sticks a bit extra too =/ gotta clean that up soon..
Old Apr 7, 2003 | 04:18 PM
neil350's Avatar
Mines has it's fair share of coke spilled and does the exact same thing.
Old Apr 7, 2003 | 04:20 PM
TobyZ28's Avatar
I'm sure anyone with an A4 has had drink spilt there, the darn cupholder holds out fine when your accellerating, but theres nothing to keep it from flying forward when you brake =/ I want a cupholder "mod" for our console
Old Apr 7, 2003 | 04:29 PM
RENE95Z's Avatar
No, I am not parking on a steep hill, or any hill for that fact. However, that is the feeling it has as if it is binding.
Old Apr 7, 2003 | 04:50 PM
brians car's Avatar
fluid
if you don't have enough trans fluid in i've found it hard to move out of park, and not only that but if you're lucky to get it out of park it won't shift out of first. its worth a try.
Old Apr 7, 2003 | 05:27 PM
ibanez6rg's Avatar
When parking on a hill, apply the hand brake, then put it in park. When leaving, put it in drive and then release the brake. This will prevent torque lock
Old Apr 7, 2003 | 05:46 PM
anasazi's Avatar
i have the SAME EXACT PROBLEM... you described it perfect
this has been brought up quite a few times on this board, and i think most cars affected were the 1995 A4's... and the part to fix it was the gizmo that doesn't let you move it out of park until the brake is pressed.
meissen
Aug 11, 2015 06:05 AM
Aug 7, 2015 01:26 PM
wesley81
Jul 27, 2015 11:31 AM
Jul 10, 2015 02:23 PM
