changing clutch fluid
Old Apr 6, 2003 | 12:47 AM
cals400ex's Avatar
i have an M6 and i want to change the clutch fluid. i have replaced the factory clutch with a borg warner clutch. what type of fluid does this take? also, how would i go about and bleed the line? is there a bleeder skrew and then i need to pump it out? any assistance would be appreciated. thanks
Old Apr 6, 2003 | 01:12 AM
turbo_Z's Avatar
why do you want to change the clutch fluid for? if you are hoping to feel a difference in the way your clutch grabs or the distance it engages from the floor then you are wasting your money.
Old Apr 6, 2003 | 01:16 AM
cals400ex's Avatar
the fluid is just old so i figured i would change it if i could figure out the correct procedure. yeah i did not think i would notice a difference but i like to keep up on these type of things.
Old Apr 6, 2003 | 10:30 AM
95 Z/28 LT1's Avatar
Super Moderator
You would be better off replacing the whole assembly with a new one from GM. I comes with a slave cylinder, master cylinder, resevoir, and the lines all assembled and pre-bled. All you have to do is take your old one out and put this one in.
PCLZ28
Dec 24, 2015 05:19 PM
anmar A
May 2, 2015 06:59 PM
captcorvette
Mar 7, 2015 12:37 PM
eazyZ
Mar 1, 2015 07:12 AM
HectorM52
Jan 30, 2015 11:08 PM
