160 deg theromostat intall?
Old Apr 3, 2003 | 11:37 PM
speed76demon's Avatar
How long does it take to do? Also is it very hard to do? And my last ? is where is it located and any instuctions out there thanks for the info
Old Apr 3, 2003 | 11:40 PM
Don't forget to make use of the search feature.
This thread was posted just a couple of hours ago:
http://web.camaross.com/forums/showt...hreadid=102703
Old Apr 3, 2003 | 11:42 PM
TMDZ28's Avatar
very easy to install.......it took my friend (who just bought a camaro, and knew nothin about it) about 20 min. it's located below the intake elbow, take the two bolt off, then take out the old one and plug in the new one......that's it
Old Apr 4, 2003 | 01:04 AM
SSnakeEater's Avatar
i was planning on getting a 160stat until i read the owners manual on how to replace the thermostat.
It said i had to drain the whole radiator, then put the stat in and refil it. Is this true? do you have to do this? sound slike a PITA
Old Apr 4, 2003 | 01:10 AM
jasons93z's Avatar
well, i just changed mine and i didnt drain the radiator. I think it says that just saying that it would be a good idea to service the whole system while changing it. Btw, only a little coolant came out, but you still need to put rags around it to protect the opti.
Old Apr 4, 2003 | 07:50 AM
Bastardcat's Avatar
You certainly do not have to drain your radiator to replace the thermostat--as stated in the link posted by Shoebox.
Old Apr 4, 2003 | 09:00 AM
TMDZ28's Avatar
no you dont have to drain the whole radiator......but it is better, if you have a big piece of towel, so that the water doesnt get into ur opti......
Old Apr 4, 2003 | 07:07 PM
kirschman's Avatar
U can replace it without bleeding the system if u are quick Have towels handy, and the stat ready, quickly R and R..
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Mar 26, 2016 08:53 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
SC97TA
Sep 15, 2002 01:10 AM
