Mass Air..96 caprice to 97 Formula?
Old Apr 3, 2003 | 09:51 AM
93transam1234's Avatar
Question Mass Air..96 caprice to 97 Formula?
The shop just called and said all my problems where from a bad mass air and O2,s. I didnt know they could make my car act so bad. but anyways will an MAF from a lt1 96 Caprice work on my car? Is it any better or worse then the OEM one? Cause i get it for free
Old Apr 3, 2003 | 10:35 AM
Any one?
Hello?
Old Apr 3, 2003 | 10:49 AM
mtxpert's Avatar
If you put the Caprice complete MAF on there you will have problems as it is 3.25" vs 3.5" for your stock MAF, HOWEVER you can just change out the sensor portion of the MAF. I've been told that the middle sensor portion is the same for all the LT1 MAF's.
Hope that helps!
Mike
Old Apr 3, 2003 | 10:54 AM
how
so how would i go about doing this?
Old Apr 3, 2003 | 11:04 AM
mtxpert's Avatar
Unscrew the allen head bolts that hold the metal ends onto the black sensor on both MAF's. Swap the black sensor portion to your Fbody MAF ends. Reinstall and tighten the allen head bolts.
Takes about 2 minutes.
Mike
Old Apr 3, 2003 | 11:11 AM
snksknr94's Avatar
The inner parts are the same but you'll probably have to do a little bit of hacking to get it to fit. I helped a guy at work put a ported F-bod housing into his Caprice, and we had to cut some tabs off the inner part to get it to fit flush against the new housing.
On a side note, Mike when you plan on doing those valve springs? Just give me a few days notice, so I don't plan anything else and we could probably get that knocked out over a weekend.
Old Apr 3, 2003 | 01:21 PM
mtxpert's Avatar
Aaron, they're DONE!!
See my new times?
WOOT
I will be going to Firebird Friday night with my new cutouts opened up. Hoping for a 12.1 or 11.99 on juice.
13.8 on motor.
Mike
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Formula Steve
Sep 19, 2015 08:48 PM
tommalcolm
Sep 11, 2015 03:39 PM
