EGR VALVE Malfunction
Old Apr 1, 2003 | 05:08 PM
thelategreatz28's Avatar
Hey,
Im getting an Egr code thats irritating me. I took out my cats and the backpressure is messin around with my egr valve.... (I think.... alot of people told me this, but I dont know for sure). I dont want to go out and get another valve, Actually I wanna just block it off or get rid of it, whats the smartest thing to do?
Old Apr 1, 2003 | 05:27 PM
TTT
Old Apr 1, 2003 | 05:55 PM
A TTT in 19 minutes is bad ettiquette on this forum (24hrs is the general rule), plus you gave no info about your car (like year) for anyone to help you.
Old Apr 1, 2003 | 05:57 PM
Sorry, Im a newbie and Im just doing that becuase Im used to the 30 second responces that I always get, but this time it wasnt so fast. My bad, Im sorry.
Its a 1996 Camaro Z28....
Old Apr 1, 2003 | 06:21 PM
I guess everyone spoiled you.
OBD-II cars like your 1996 can get unhappy with backpressure changes. If you want to get rid of it, you can have it programmed out to keep the SES off. You can then get block off plates or just disconnect the vacuum source and leave it alone.
How are you getting by with no cats in California?
Old Apr 1, 2003 | 06:33 PM
Just passed smog 2 weeks ago and I took the cats off the same day
Also, you said I can have it programmed out.... whats an alternative way to get the ses light out of the way? Will the block off or vacuum disconnection make it go away?
Old Apr 1, 2003 | 06:50 PM
Programming it out is about the only viable way to do it. Any time the pcm turns the EGR on, it will try to verify that it is working. If it does not detect the correct conditions, it will throw a code.
I have heard of another alternative for fooling the pcm, but it requires some odd parts and wiring. Not nearly as "neat" as having it programmed out.
14
Aug 11, 2015 12:03 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
