If I am using aan MSD box should I ???
Old Apr 1, 2003 | 10:32 AM
94Zpower's Avatar
should I change the gap on my plugs?
a friend mentioned this to me but I don't know if he is right or not?
thanks.
Old Apr 1, 2003 | 11:14 AM
PatriotTA's Avatar
I ordered my 6AL but its not here yet. But, my friend was telling me that the manual says to increase the gap on your plugs. You should be using steel plugs like ac delco if you are using an aftermarket ignition. Look in the manual, it should state how much to increase your gap.
Old Apr 1, 2003 | 12:02 PM
94Zpower's Avatar
do you know what will happen if you don't increase the gap?, I just fininshed changeing my plugs on saturday and I now got a deal on a 6A! I really don't want to do the plugs over again!!!!!!
Old Apr 1, 2003 | 12:16 PM
PatriotTA's Avatar
Nothing bad will happen if you don't re-gap your plugs, but just know that they are no longer at their optimum gap. You could stand to gain some power if you increased the gap, but not very much if you are using steel plugs. If you are using platinum or some other plugs, you could gain more if you increased the gap, but you would have to really gap the hell out of them. That's why I said in my earlier post that the steel plugs are the way to go. Here's a good article on spark plugs if you want to read it, there's info about gapping and aftermarket ignitions at the bottom with some numbers to back it up.
http://web.camaross.com/forums/showt...=article+plugs
Old Apr 1, 2003 | 12:22 PM
94Zpower's Avatar
Thanks alot!
Old Apr 1, 2003 | 12:32 PM
Pandamonkey's Avatar
When I did my plug, I put in my MSD 6A then.........I was wondering about using platinum plugs with the box.
So I phoned MSD.
They didn't recommend it. They claimed the plugs wouldn't last as long as they should......
Old Apr 2, 2003 | 12:38 AM
HungryT/A's Avatar
Exactly! I think everyone should ditch their plats, because they're a POS! I had changed them after 8000m, 5 of 8 were missing the platinum tip. To gain power (minimal), you should go with COPPER plugs, not plats.
I can't stress this enough, plats are a POS!
Old Apr 2, 2003 | 01:22 AM
bachehbad's Avatar
is the MSD 6A just a coil??? and if so how do you like it so far?
Old Apr 2, 2003 | 02:24 AM
HungryT/A's Avatar
No, it's an ignition amplifier. Read it here:
msdignition.com
Old Apr 2, 2003 | 07:19 AM
94Zpower's Avatar
I installed both the msd blaster coil and the 6A box but I havent driven the cars yet because it is still in storage until the 20th of april, but I'll let you know if it helps.
Quickss96
Jan 29, 2016 05:56 PM
zk06
Sep 9, 2015 11:39 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
canuck94z28
Aug 19, 2015 05:50 PM
88IROC_Z
Jul 22, 2015 11:38 PM
