a quick rust question!
Old Mar 31, 2003 | 10:02 PM
Terran2k's Avatar
on the bottom of the water up....Im going to use one of shoebox's pics as a guide, hope he doesnt mind... but
http://csce.uark.edu/~jgbertr/rb/temp_sensor1.jpg
see that hose right under the word "front" in green and white...that metal piece that my hose is connected too is covered in rust, now is this normal? his is shiney. any1 else's has rust on it, or should i have it looked at before it rusts thru and causes a leak of some sorts.
Old Mar 31, 2003 | 10:20 PM
Prorac1's Avatar
It should be fine, probably just from condensation. No biggie, hope this helps. prorac1
Old Apr 1, 2003 | 05:50 AM
Mtrhds94Z's Avatar
Those are stainless steel, so can't 'rust thru'... [and can't really be replaced readily since they 'press' in..]
Old Apr 1, 2003 | 12:04 PM
97firechicken's Avatar
It would take a while for it to rust thru. im restoring a 54 Chevy truck that has rust all over it and and has been sitting outside for many years, so i think you will be fine for a while. IMO
Old Apr 1, 2003 | 02:09 PM
Mtrhds94Z's Avatar
I repeat the AC Delco LT1 pump inserts are stainless steel and WON'T rust...
Old Apr 1, 2003 | 11:34 PM
Terran2k's Avatar
hey all thanks for the replies, I just wanted to make sure it wouldnt break and leak all over my opti, but looks like Im safe, I thank you.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Lederman1976
Nov 30, 2014 05:21 AM
