Lining Up Hub/Balancer to #1 TDC
Old Mar 31, 2003 | 05:47 PM
95 Z/28 LT1's Avatar
Super Moderator
I am going to be removing my Balancer and hub to see if they are lined up properly with #1 TDC. The hub has either slipped, or was never installed properly after the engine rebuild.
My question is, is where are the timing marks for TDC on the hub or balancer? The hub has three arms and one of them is pointed, is that it? Or is there a timing mark on the outside edge of the balancer? I looked the balancer over and didn't see one on the edge like on most engines, probably due to the fact that the belt rides directly on the balancer.
Any help would be greatly appreciated, as I did a search and haven't found anything that describes the location and what the timing mark looks like.
Also, when the mark is at 12:00 is that #1 TDC?
Thanks in advance.
Old Mar 31, 2003 | 05:52 PM
The pulley has an arrow or mark on the front and the hub has a line marked on it behind the spokes.
Old Mar 31, 2003 | 05:57 PM
Super Moderator
So does straight up, (12:00), mean #1 TDC? For both marks?
I guess both marks will line up together, right?
Old Mar 31, 2003 | 06:10 PM
Yes, they match and straight up (12) could be #1 or #6, depending on where you are in the firing order.
Boss002
Jan 20, 2016 12:17 PM
pimpen1024
Aug 19, 2015 08:36 PM
Fastbird93
Jul 11, 2015 04:37 PM
Jul 10, 2015 02:23 PM
Boss002
Jul 9, 2015 03:33 PM
