Fresh Offf the Dyno - Hotcam #s
Old Mar 29, 2003 | 02:06 PM
Scott 97 Z28's Avatar
Talking Fresh Offf the Dyno - Hotcam #s
RWHP = 349.5 @ 6400
RWTQ = 351.6 @ 4500
I've gotta say...
The program is perfect. The A/F ratio was nearly flat through the entire pull and the power and torque curves are really smooth. It looks like I'll be in the mid 12's this year.
Mods:
Stock = MAF with screen, Throttle body, Intake, and Heads
LT4 Hotcam Kit
4.10 Gear
SLP 94-95 Headers
No Cats
SLP Loudmouth
Home Made CAI
TB Flow Booster
MSD 6 Ignition
Taylor Wires & NGK TR55 plugs
160 degree thermostat
TB bypass mod
Deleted EGR & Airpump
Chassis mods by BMR, SLP, & Kenny Brown
Program By:
WWW.PCMFORLESS.COM
RamAir95TA's Avatar
350rwhp with just a hotcam....very impressive my man!
Old Mar 29, 2003 | 02:10 PM
Smokn '94 Z's Avatar
Re: Fresh Offf the Dyno - Hotcam #s
Originally posted by Scott 97 Z28
RWHP = 349.5 @ 6400
RWTQ = 351.6 @ 4500
I've gotta say...
Mods:
LT4 Hotcam Kit
4.10 Gear
SLP 94-95 Headers
No Cats
SLP Loudmouth
Home Made CAI
TB Flow Booster
MSD 6 Ignition
TB bypass mod
Program By:
WWW.PCMFORLESS.COM
Hey Scott. Where did you dyno the car? Nice #'s. Also you do have a bit of head work too right?
Old Mar 29, 2003 | 02:14 PM
joeSS97's Avatar
SWEET
Old Mar 29, 2003 | 02:17 PM
94F1Z28's Avatar
Very nice
Old Mar 29, 2003 | 02:33 PM
EvlViln's Avatar
How much work did you do to the heads? Did you put bigger valves in or did you have runner work done? What did the heads flow?
Nice #s by the way?
Old Mar 29, 2003 | 02:53 PM
95TA8280's Avatar
Tell me those aren't on stock heads without any work to them because if they are, I'm depressed with my numbers
Old Mar 29, 2003 | 03:00 PM
Rich_z28's Avatar
I'm currently looking at a cam swap. I was looking at one of the kits from Combination Motorsports, but it sounds like the programing for the Hot Cam is better, since it's worked with more. Plus I'd be happy with numbers like yours. Maybe, I'll start looking into the Hot Cam a bit more. Nice numbers.
Old Mar 29, 2003 | 03:08 PM
gb95zconv's Avatar
WOW....I thought my hotcam setup was strong at 342rwhp. I had ported stock heads....nice nimbers.
Old Mar 29, 2003 | 03:16 PM
Grease's Avatar
Wow, great numbers. Thats about the most I've seen with a Hotcam. Bryan definately has the hotcam figured out.
Old Mar 29, 2003 | 04:40 PM
The heads have never been touched! I had it dyno'd at Speed Inc. with about 30 other MFBA members. Everyone was impressed (especially me) with the results given the current mods. I was hoping for at least 330 hp but I never expected 350!
FYI - it was pretty cool today (about 35 degrees) and the car was cold when the put it on the rollers. I'm sure that has something to do with the numbers.
Old Mar 29, 2003 | 04:59 PM
EvlViln's Avatar
Brayn Herder has his head up his ***. And i happen to know of a guy in Southern California with the Hot Cam and STOCK EXHAUST MANIFOLD that pulled 370hp to the ground and 365 FTTQ. TUNED BY TAD! And it passed smog in so cal with numbers that where better than stock.
Old Mar 29, 2003 | 05:38 PM
Exclamation
Don't you think you are being a bit harsh? There are some factory freaks that run low 13's stock. Maybe your friend has one of these cars? Maybe your friend has some head work done too.
Then again, maybe your friend is imaginary... With comments like this you wont be making more.
Old Mar 29, 2003 | 05:45 PM
stik6shift93's Avatar
I doubt he was lying. Scott what color was your car, I was also there this afternoon. Nice numbers man
Old Mar 29, 2003 | 05:50 PM
Originally posted by stik6shift93
I what color was your car
Red with the black top / T-tops
Mine was the loudest LT1 there (I left after lunch)
