Those with rollbars, come in side!
Ok, so I am getting 5 point belts when my rollbar is done. How did you guys who have removed your factory belts cover up the not so attractive void in the headliner? In addition to the yellow foam looking bad, the headliner is also a little looser. Any suggestions would be much appreciated.
I've got the roll bar contoured so tight against the headliner that it completely blocks the view of the opening for the shoulder harness in the headliner. Also means the headliner can't sag. The opening is an inch or two behind the bar and not visible unless you lay down where the back seat used to be. I also made fillers for the openings in the rear fender liner panels where the rear seat shoulder harness came through.
Rear harness opening fill
Top bar contoured against headliner
07-10-2015 02:23 PM
