paint ideas need help
Re: paint ideas need help
I got this picture off Google images- just searched Camaro red hockey stripes. Figured it would help answer your other question wanting black wheels with a chrome lip. Took about 3 seconds to find. I know its the 98+ front-end but should give you an idea...
There are lots of different style of hockey stripes out there so its hard to determine what you want. Best bet is take some time either searching Google and see what you can come up with...
I either posted in this topic, or you've started this topic 3 or 4 times with the same pic...
Either way, hockey stick stripes look HORRIBLE on '93-'97 Camaros because the front fender for those years flares out while the '98-'02 does not. I've never ever seen a '93-'97 with a hockey stripe that didn't look gross.
you should have a custom paint job done to your hood... of a "civic"(civet) cat crappin in a coffe mug. http://en.wikipedia.org/wiki/Civet
That one in particular looks bad- I have seen a couple 93-97's with hockey stripes that look good. The shape, cut, arc and placement are less forgiving on the earlier cars- but then can look if done right IMO...
^^ this is probably the only '93-'97 with anything on the side I've ever liked. I think it flows surprisingly well with the bodywork, though it definitely looks overdone to some extent.
There's a few others I've seen with stuff on the side, but none of the designs are simple like that one above is... sort of.
05-01-2015 01:14 PM
ModdedNerd
12-14-2014 10:28 AM
