LT1 headlight blackouts.
Old 07-05-2006, 06:07 AM
NOVA5's Avatar
Looking for some blackouts for headlights, trick is they need to have some panels on the side to secure them into the housing. I can't find any pics of them Off the car to see how they attach to the LT1s.
Any info would be great, thanks.
NOVA5 is offline
Old 07-05-2006, 06:50 AM
Z28SORR's Avatar
Re: LT1 headlight blackouts.
Not sure what you mean. But the ones I got for my 97 had three brackets that stick to the housing, double sided sticky tape, and the blackouts velcro to them.
These required no drilling.
Z28SORR is offline
Old 07-05-2006, 07:20 AM
NOVA5's Avatar
I would need it to have sides on it for the method i would use to secure it, plus im planning a nonstandard use for them, hence the need for knowing how they connected.. thanks for that info.
NOVA5 is offline
Old 07-06-2006, 05:55 PM
CALL911's Avatar
Mine on my 95 attached to a fitting on the black part in front of the lights. The part required drilling and placing 2 screws on each side unfortunatly. It's hard to describe but basically the darkout cover has a flat prong on the inside that slides under the other fitting attached to the black part of your bumber in front of the lights.
CALL911 is offline
Old 07-06-2006, 06:47 PM
NOVA5's Avatar
Could i perchance ask you to pop your hood and get me some pics of that? remember what brand/supplier they were? they may be close to what I need.
NOVA5 is offline
Old 07-06-2006, 07:03 PM
CALL911's Avatar
Sorry man. I eventually decided that I didn't like the way they looked at night, and removed them. And later, got the bumper repaired and repainted over the drilled holes. I think they were by GTS. I can't remember for sure.
CALL911 is offline
Old 07-06-2006, 08:36 PM
NOVA5's Avatar
Thanks for the info. now to see if i can find a pic of the GTS ones, problem is they usually use a basic pic of 1 car for every model. sad way to advertise and sell a product.
NOVA5 is offline
Old 07-07-2006, 09:28 AM
Brangeta's Avatar
You could always spray some transparent black on the headlamps. Worse comes to worse, you'd have to go to Autozone and buy 4 new ones.
I wouldn't recommend doing that to the fog lights though, they aren't easy or cheap to find or replace.
Brangeta is offline
Old 07-07-2006, 10:22 AM
NOVA5's Avatar
That won't work for my use. a blackout panel is required, i may have to figuire out a different attachment method for what i want to use it for if they don't come with tabs on the side anymore.
NOVA5 is offline
ChrisFrez
02-15-2015 08:12 AM
94Z28LS1toLT1
02-10-2015 10:19 AM
Injuneer
Advanced Tech
01-15-2015 02:49 PM
CaRParts102
12-06-2014 08:45 AM
12-04-2014 11:56 AM
Quick Reply: LT1 headlight blackouts.
