installing a new steering wheel
Old 06-17-2009, 06:53 AM
felon_gt1's Avatar
Question installing a new steering wheel
so im looking to replace my worn out s.w but im not sure if their is anything special that i need to know,size,bolts, ext...or do i just buy a universal one and bolt it up, any help will be appr. thanks guys
felon_gt1 is offline
Old 06-17-2009, 12:15 PM
Mikes 1994 z28's Avatar
Get a corvette steering wheel.
Mikes 1994 z28 is offline
Old 06-18-2009, 06:04 PM
Bud M's Avatar
You will probably need an adapter with any aftermarket wheel
Also disconnect the battery and let the car sit for a while to discharge the airbag
Do a search, its been covered before. Its been so long since I did mine I don't remember half of the details.
Bud M is offline
Old 06-19-2009, 02:16 AM
Brangeta's Avatar
The guys on LS1tech have a topic about corvette steering wheels and how nobody has ever gotten it to work or fit or something. It's ALMOST a funny topic.
Brangeta is offline
Old 06-23-2009, 10:06 PM
budgetlt1's Avatar
i just replaced mne this afternoon. you will need to pull the airbag fuse which is in the dash fusebox at bottom left. the airbag is held on with torx bolts that are accessed from rear of steering wheel. remove airbag and disconnect yellow connector. set aside. next loosen the steering wheel retaining nut (21mm) and remove nut. install steering wheel puller. remove steering wheel. set new steering wheel in place-there is a double spline so it only goes on one way. reinstall steering wheel nut. make sure to get the horn contact back in the hole before installing the airbag again. then reinstall fuse and you should be good.
hope that helps
budgetlt1 is offline
Airplanedoc
02-01-2015 07:14 PM
CaRParts102
12-06-2014 08:45 AM
ro2207
12-04-2014 06:18 PM
SLIMJIM
01-07-2003 11:06 AM
Darth Xed
13
07-22-2002 12:45 PM
Quick Reply: installing a new steering wheel
