How do you remove the steering wheel?
Old 05-27-2003, 04:46 PM
1COOLPC's Avatar
Can somebody please tell me how to remove the steering wheel on my '02 Z28? Ever done it?
By the way;
1COOLPC is offline
Old 05-27-2003, 04:58 PM
It's Cochese!'s Avatar
I'm not familiar with the 02 Z, but on most cars:
Remove screws on back side of base of wheel. Remove airbag cover, taking great care to not set it off (remove neg terminal). You should be able to disco the airbag and remove it. Then you will need a special tool to remove the wheel from the column.
I can't remember the name of the tool, I know someone will.
It's Cochese! is offline
Old 05-27-2003, 05:00 PM
1COOLPC's Avatar
If I remove the battery terminal I am in no risk of blowing the bag? I was under the impression they had a back up power source. Does it hurt when you get spanked with one?
1COOLPC is offline
Old 05-27-2003, 05:03 PM
95 3.8's Avatar
you can get most of those tools at auto-zone.
95 3.8 is offline
Old 05-27-2003, 05:50 PM
It'll leave a few burn marks, plus you'll be out the xxx amount of money you could sell it for. That's why I said be careful, in addition to disco the battery.
Old 05-27-2003, 09:12 PM
AW/whiteZ-28's Avatar
Yea rent the tool from auto zone or pepboys it's called a steering wheel puller don't worry about haveing to pay they give you the money back after you return it and BE CAREFUL taking that damned air bag off
EDIT: you do have the installation kit for the aftermarket wheel right???
AW/whiteZ-28 is offline
Old 05-27-2003, 09:21 PM
BadLiLBowtie's Avatar
yup, you can buy a steering wheel puller from auto-zone. as for disconecting the air bag, cruise control, etc. I don't know.
BadLiLBowtie is offline
Old 05-27-2003, 10:55 PM
You might want to read the removal procedure in the factory manual or even the Chiltons manual. Is has precautions regarding the time required for the capacitor in the deployment system to discharge, AFTER the battery is disconnected. After waiting, disconnect the yellow airbag harness connector at the base of the steering column and you should be OK. There are also some specific steps for removing the airbag harness contact ring that floats on top of the steering column shaft. I used the Chiltons procedure, and salvaged all the parts for resale.
Injuneer is online now
Old 05-28-2003, 01:18 PM
97QuasarBlue3.8's Avatar
Yeah, don't remove that airbag unless you know exactly what you're doing.
If one of those things go off, and you're in close proximity of it, prepare to get royally b**** slapped. I believe most injuries from airbags comes from you actually hitting yourself if you're holding your hands/arms in front of you or with tools. It happens so fast, it just pushes your arms or whatever's in front of you right in your face. Prepare to see stars.
97QuasarBlue3.8 is offline
Z28amustangklr
Middle Atlantic
03-28-2015 03:08 PM
Airplanedoc
02-01-2015 07:14 PM
CaRParts102
12-06-2014 08:45 AM
ro2207
12-04-2014 06:18 PM
Darth Xed
13
07-22-2002 12:45 PM
Quick Reply: How do you remove the steering wheel?
