Help with center console
Old 06-13-2012, 05:09 PM
LT1 Tony's Avatar
Can any one tell me how the shifter (automatic) comes out so I can replace the center console on my 1997 Camaro?
LT1 Tony is offline
Old 06-13-2012, 07:16 PM
jloshotz's Avatar
If you drop the shifter down to low gear and look on the front side of the shift ****, you should see a big black "staple". Get behind it with a flat blade screwdriver and pry it out just like you would a staple. Then the **** just pulls right up and off, allowing you to get the shift plate off. Pretty straightforward from there.
jloshotz is offline
Old 06-14-2012, 08:17 PM
LT1 Tony's Avatar
Re: Help with center console
Thank you very much jloshotz. I will be doing that project this weekend.
LT1 Tony is offline
Old 06-14-2012, 08:40 PM
jloshotz's Avatar
Anytime, good luck with it!
jloshotz is offline
Old 06-16-2012, 12:43 PM
LT1 Tony's Avatar
I pulled the staple out and the handle still isn't budging. I'm afraid that the handle is going to break.
LT1 Tony is offline
Old 06-16-2012, 12:56 PM
jloshotz's Avatar
It will come up, it just probably has never been moved...try closing an adjustable wrench on the shaft just below it, and tap on the wrench from underneath. It's just stuck. Actually, if the staple is out, try giving the button a few good bumps, that should loosen it. Think of it this way....if the staple wasn't there, the **** would theoretically lift up on the shaft every time you pushed the button. Do this with the key forward so the shift lock doesn't interfere
jloshotz is offline
Old 06-18-2012, 07:07 PM
LT1 Tony's Avatar
Thank you for the info jloshotz. I will try that this weekend.
LT1 Tony is offline
Old 07-01-2012, 07:56 PM
LT1 Tony's Avatar
thanks joshotz, the adjustable wrench trick worked like a dream.
LT1 Tony is offline
Old 07-01-2012, 08:50 PM
jloshotz's Avatar
Good to hear
jloshotz is offline
LT14LIFE
11-15-2015 06:22 PM
WobblySausage
10-07-2015 02:44 PM
WobblySausage
10-07-2015 10:09 AM
Daluchman1974
09-11-2015 06:12 AM
Henson071
08-04-2015 09:32 AM
Quick Reply: Help with center console
