Cleared up under the hood a bit.
Old 09-20-2002, 11:59 PM
Dark Angel's Avatar
OK, here;s the deal, I removed the A.I.R. system completely and thought since I had a little more room, I would re-run the wiring that went over the passenger fender. I also threw a coat of paint on the drivers fender to see what it would look like.
What are you opinions.
Check this out.
Dark Angel is offline
Old 09-21-2002, 12:25 AM
Roshambo's Avatar
The fender looks great, you need to do the other one!
And it looks like you have some wierd tubing going into your throttle body, you should remove that to free up some room too!
-Roshambo
Roshambo is offline
Old 09-21-2002, 12:45 AM
kevkop94TA's Avatar
Thumbs up
Definitly looks a lot better/cleaner. Do the other side and you'll be all set. Great job.
kevkop94TA is offline
Old 09-21-2002, 02:03 AM
Prince's Avatar
Looks awesome !!! Not sure about freeing up room, I'm not too familiar with what the LS1 engine bay's looks like...but it looks good none the less .
Dave
Prince is offline
Old 09-21-2002, 06:57 AM
JackZ.Twenty8's Avatar
Ah, so you finally have a website!! Looks good.
Whose red z is that in the picture? It looks sweet!!
JackZ.Twenty8 is offline
Old 09-21-2002, 07:29 AM
Dark Angel's Avatar
That red Z? Hmm, why I believe it's your isn't it Jack? Thanks for the compliments. I know I need to do the other side.
Old 09-21-2002, 08:06 AM
Oh yeah, I knew it looked familiar.. It's really too bad it's not over there in Texas with that black Z..
Old 09-21-2002, 10:30 AM
Dark Angel's Avatar
Your stuck in germany for the rest of your life!!! When you getting your site back up and running?
HibachiZ28
11-06-2015 12:53 AM
sleeperZ96BT
09-09-2015 08:28 AM
Devinfoote87
09-04-2015 05:52 PM
95mysticta
08-20-2015 07:43 PM
alphaauto
07-26-2015 04:40 PM
Quick Reply: Cleared up under the hood a bit.
