93 to 97 headlights
93 to 97 headlights
ok this is gonna sound stupid but i have a 99 camaro front was smashed so i put the 93 to 97 front end on it and idk which is the high beam or the low beam so what light is on the outside and what one is on the inside thanks
Re: 93 to 97 headlights
I had the same issue. At the top of my head i remembered that the plugs will only fit into the correct light. And on top of each light is a tiny R or L meaning left or right. The two R's go on the right, and then just try each plug to see which one goes with which. Like i said the sockets are slightly different for the high beams so it wont let you plug in the wrong wire.
jackpawt883
09-10-2015 08:53 PM
08-17-2015 09:50 AM
Henson071
08-04-2015 09:32 AM
