4th Gen Taillight Replacement (Bulbs)
Old 02-17-2005, 09:33 PM
6SpdLT1Z's Avatar
I found out that my one of the bulbs on my passenger side taillight is burnt out. The bulb that is burnt out is the far right one on the passenger side. To remove the light I just need to pull back the carpet in the hatch, remove a couple bolts to pull out the taillight and then unscrew the old bulb and put in a new one?
What bulb do I need to replace it? It's the far right one on the passenger side.
6SpdLT1Z is offline
Old 02-17-2005, 09:58 PM
Z95m6's Avatar
Re: 4th Gen Taillight Replacement (Bulbs)
for some reason i think the bulbs are 194's. There are some places on the net that will tell you the exact bulb. You just pull the carpet back and there will be plastic wing nuts you take off and the light will come out.
Z95m6 is offline
Old 02-17-2005, 10:10 PM
6SpdLT1Z's Avatar
k.. maybe I will redneck it and do it in the parking lot at autozone or w/e.
6SpdLT1Z is offline
Old 02-17-2005, 10:30 PM
NOS2006's Avatar
As Z95 said above, it's REAL easy to do. I just replaced mine a few months ago. What the number is though? I can't remember. Just call your local autostore and they should be able to tell you exactly what part you're looking for by punching your year/model car in the computer. That's how they do it around here at least...
NOS2006 is offline
Old 02-17-2005, 10:50 PM
6SpdLT1Z's Avatar
It sounds easy enough that I can just take it out and take it in with me and I've had two people tell me it's 194's so that sounds like it is it.
Thanks guys!
6SpdLT1Z is offline
Old 02-17-2005, 11:18 PM
RacingTiger04's Avatar
im thinkin thats what it was, and thats exactly what i did when mine went out, took the light out in the parkin lot went in got a new one and put it back in if its the one on the very end on the outside im positive it was a 194.. have fun gettin carpet burn though, thats the only part i remmeber bein bad cause that carpet is pretty stiff lol
RacingTiger04 is offline
Old 02-17-2005, 11:22 PM
Z95m6's Avatar
here is a good link it tells you what bulb you need for pretty much everything on your car. http://www.sylvania.com/ConsumerProd...RG-Results.htm
Z95m6 is offline
Old 02-17-2005, 11:27 PM
6SpdLT1Z's Avatar
Nah, my carpet sucks... it comes out real easy in the back hatch.
6SpdLT1Z is offline
Old 02-17-2005, 11:46 PM
NOS2006's Avatar
Yeah! I'll second that.. it sucks like none other!
NOS2006 is offline
Old 02-18-2005, 03:46 PM
6SpdLT1Z's Avatar
Yup the far corners are 194's, piece of cake to replace.
Thanks.
6SpdLT1Z is offline
karguy16
03-06-2015 01:31 AM
silvermansteve
03-04-2015 05:02 PM
squarehead
01-15-2015 07:02 PM
stars1010
07-15-2002 03:51 AM
Doug Harden
11
07-14-2002 04:31 PM
Quick Reply: 4th Gen Taillight Replacement (Bulbs)
