Stupid Big Block Question
Old 04-18-2008, 10:35 PM
rallysport92's Avatar
Does anyone know how much a gen 5 big block can be bored and how big can I go with the stroke?
rallysport92 is offline
Old 04-18-2008, 11:06 PM
Stephen 87 IROC's Avatar
Mark IV and Gen V blocks can be safely bored to 0.060" over
A 4-1/4" stroker crank can probably be installed but as with any production block, clearances need to be checked.
Stephen 87 IROC is offline
Old 04-19-2008, 04:58 AM
MachinistOne's Avatar
The 4.25" cranks fit fine in the late model blocks.
MachinistOne is offline
Old 04-19-2008, 06:19 AM
Moderator
rskrause's Avatar
Weren't there some Gen V 502 blocks that had siamesed bores? If it's one of those it can be bored to 4.500". Otherwise don't go more than 60 or 70 over. 60 over (4.310" is preferred by many engine builders.
Rich
rskrause is offline
Old 04-19-2008, 12:46 PM
Is it possible to go any bigger with the stroke?
Old 04-19-2008, 01:46 PM
With a stock 454 Gen V block? Probably not. To clearance the block for more stroke, you risk hitting a water jacket. Going longer than 4.250" stroke usually means also going to a tall deck block so that the wrist pin stays out of the piston rings.
If you want a really long stroke, buy an aftermarket block. Going to a much longer stroke means having the pan rails clearanced and the bottom of the cylinders clearanced. All the good aftermarket blocks are already clearanced for a stroker crank and are cast differently so more clearancing doesn't cut into water jackets. The alternative is to fill a production block with blok fill.
A 454 block has a 4.250" bore. The 502 blocks are 4.470" and can be bored to 4.530". I don't think there were any production 502 Gen V engines.
Old 04-19-2008, 11:26 PM
byrons1502's Avatar
4.25 cranks are an easy fit when done correctly. the blocks can be bored more than .060 but need sonic checked first.
byrons1502 is offline
Old 04-21-2008, 02:14 PM
So no recommendations for anything over 505ci on this stock block? I will take this advice thanks for the info. It seems I have a different motor and motor question every week and u guys take the time to answer all of them. Thanks
Old 04-21-2008, 03:56 PM
ulakovic22's Avatar
Personally I'm running a Gen V 502 block that is bored .100 over. Need to sonic check them for sure. Recommened max bore on mine was 4.5 which was only .030 over, but it wasnt' big enough for me What are you looking for because you will have no rebuilds in the block if you go big.
ulakovic22 is offline
Old 04-21-2008, 05:51 PM
Moderator
rskrause's Avatar
That's what I thought (that there are Gen V blocks with siamesed bores). But unless it's a siamese bore block, 70 over (4.320) is about as far as you want to go. Only exception is some of the early, rare truck blocks.
Rich
rskrause is offline
Old 04-21-2008, 09:39 PM
I wanted to go as big as I can possibly go right now. In the future once I get a little more driving experience under my belt (and more money) then Ill go huge. Im trying to break into the drag radial/stock supension circuit so I was gonna hit it with a pretty big shot of nitrous after I get some bracket time.
Old 04-21-2008, 09:48 PM
ulakovic22's Avatar
Depending on your bore size you can go anywhere from 496-510 approx. unless you want to go aftermarket block. That can get expensive though. If you can fit it, get a tall deck block and then you can run a 4.375 or 4.5 stroke Of course those would be earlier Mark IV blocks, not a Gen V. Also Gen V have no provision for a mechanical pump, just FYI.
Moderator
rskrause's Avatar
Keep the overbore to a minimum if you are going to be making your hp with the juice. A good ring seal will be worth more than the gain from boring. Go 30 over (4.280") with a 4.25" crank. That's 489ci with a nice, thick cylinder wall and you can use a shelf piston. I prefer a short rod with big nitrous to decrease dwell at TDC and keep peak cylinder pressure down a little, but that is an endless debate.
This is assuming a stock, non-siamesed block.
Rich
rskrause is offline
Old 04-21-2008, 09:52 PM
ulakovic22's Avatar
I haven't done too much research but short rods are good and bad. Stock is too short and tends to push the walls out, but I've read that a lot of builders want a shorter rod because they tend to build torque early. Those same builders also say that if you don't start getting your torque in by 2000-2500 then your motor will be a turd, lol.
Old 04-21-2008, 09:58 PM
Wat kind of pistons should I go with? Do I absolutely have to use nitrous spec'd pistons or can I use any forged piston?
Quick Reply: Stupid Big Block Question
