Offset vs. Centerline solid roller lifters?
Old 02-15-2005, 01:40 PM
  #16
racer7088's Avatar
Thumbs up Re: Offset vs. Centerline solid roller lifters?
Originally Posted by jimlab
AFR 215cc RR heads. Note the position of the intake valves in relation to the intake ports.
http://home.gci.net/~jimlab/images/H...d/P1020025.jpg
http://home.gci.net/~jimlab/images/H...d/P1020031.jpg
Offset lifters (0.180" intake) and rockers (0.450" intake, 0.100" exhaust).
http://home.gci.net/~jimlab/images/Misc/P6200017.jpg
http://home.gci.net/~jimlab/images/E...d/P1190101.jpg
According to the Crower catalog, the AFR 220s and 227s use the same rocker offset and the 180s and 210s have a 0.250" intake offset.
That looks really nice Jim!
racer7088 is offline
Old 02-16-2005, 01:16 AM
  #17
1racerdude's Avatar
Originally Posted by racer7088
The AFR227s have offset valve locations and to get the most correct geometry is why you use the offset lifters too! You guys are getting confused and you're also believing the AFR catalogue is right! The 227 and 215RR have the same stands in REALITY but not in the catalogues.
I am speaking of running stud mount RR's not shaft rockers.
I'm not confused about the stud mount but haven't assembled a set of 227's with shaft rockers on an engine.
1racerdude is offline
G-BODYT56
01-14-2022 11:14 PM
95chwagon
10-16-2015 12:24 PM
9t4lt4z28
10-02-2015 10:28 AM
Z Power
09-19-2015 11:19 PM
Daluchman1974
09-11-2015 06:12 AM
Quick Reply: Offset vs. Centerline solid roller lifters?
