Mains Rods Rings
Mains Rods Rings
Here is my dilema. I have a 96 camaro with an lt1 350. The motor is out of the car and everything is removed from the engine block except the rotating assembly. I do not have enough money to get the block completely rebuilt. Again the pistons, rods, crank and mains have not been removed from the block. I want to put the car back together but I am not sure if I should replace all the bearing and rings. The engine never spun any bearings or any damage what so ever. The motor is in prestine condition. It had good cylinder pressure before being pulled. I am just bouncing back and forth on wheather to freshin the motor up or not. What do you guys think and what would you recommend for replacement parts"? No machining will be done, so all stock sizes on everything.
replacement parts
Stock crank unless your going forged is what iv heard
Maybe some Eagle rods
Like I said not real sure where your going with it, but if its just a freshen up, id add some bearings atleast.
If you can't afford to have the bottom end rebuilt, and the numbers were good before you took it out - it's best to leave it alone. I take these motors apart at 180K+ miles and the bearings and lower end parts look like brand new if the motor has been well maintained.
But like was said - why did you pull the heads?
I orginally pulled the motor 4 years ago to do a 383 stroker but never got a enough money to finish it. I want to put everything back together so I can enjoy this car once again. I am planning on putting a lt1 hot cam in that I picked up a while back. Since I am there I was not sure if I should replace all the bearings and rings but from the sounds of it I should put the motor back in the car. I appreciate everyones input. Thanks Again.
Check the front bearing like he said and if it's ok then slap it all back together. If the bearing looks good, it can't hurt to get a larger oil pan and a HV oil pump setup. Would be some good insurance for minimum investment.
Rich
Campbellb48
07-05-2015 06:31 PM
