t56 experts inside please............
Old 09-04-2002, 07:41 AM
black84 z28's Avatar
Post t56 experts inside please............
i was playing around last night...practicing launches.....went to shift second and it banged loud and now when i shift into second...nothing...everyother gear works perfect...the clutch is a mcloed
shift fork?
black84 z28 is offline
Old 09-04-2002, 11:43 AM
Eric Bryant's Avatar
Post
Might be, or you wiped out the synchro hub teeth on the 2nd driven gear. I'm guessing the later, as the shift fork would have to be bent enough to engage first in the neutral position if it wouldn't grab second at all. You should probably take it apart for inspection before you run the broken bits through the rest of the trans and cause bigger problems.
Eric Bryant
'96 Impala SS (LT4 396, T56, "firm" suspension)
'96 GMC K2500 (parts hauler/dune runner)
'92 Roadmaster wagon (winter beater)
'01 Honda Accord LX V6 Coupe (wife's car)
http://www.bryantperformance.com
Eric Bryant is offline
Bxlt1
09-29-2015 03:18 PM
autoxr166
09-25-2015 04:21 PM
Daluchman1974
09-11-2015 06:12 AM
94ZinEdgewater
09-08-2015 09:55 PM
Quick Reply: t56 experts inside please............
