350 Z28 swap into a 95 camaro
Old 05-06-2012, 11:13 AM
scorpo's Avatar
Hi guys need some help bad,,I'm doing a swap to my 3.4 95,,,,I want to swap all the tpi drive train ,or what I can but still want to retain stock gages a.c , want to keep the fuel injection as i am doing more to the engine,,just need help with the vacuum lines n engine harness ,,I got the whole car,,91 Z28 ,350 tpi ,so i have everything ,exempt the mass air flow,for some reason they took it out but I'm gettin one from summit,but i want to wire it right ,,don't care if engine is stand alone ,that would be better,just don't like all this sensor crap,,want a real motor that can go on itself ,,not many sensors on this engine so won't have none of the bull**** problem ,,thanks guys ,,I know about the cut to the top bay ,,just help out with all ,thanks
scorpo is offline
Old 05-06-2012, 01:46 PM
Re: 350 Z28 swap into a 95 camaro
Post a topic only once. You hurt yourself with the second post, because you left out a lot of the facts you included in this on. We also suggest that you not test the language filter.
Injuneer is offline
Collector Car
12-17-2014 01:12 PM
CaRParts102
12-06-2014 08:45 AM
07-04-2005 05:00 PM
30thZ286speed
08-03-2002 04:54 AM
2000silverz28
07-20-2002 06:14 AM
Quick Reply: 350 Z28 swap into a 95 camaro
