what is the best way to fix an oil leak?
Old 06-21-2004, 11:16 AM
breakthelawinaz's Avatar
i got my engine all together, it leok beautiful runs awesome, but i have a problem, it leaks oil! it is coming out of the pass side where the timing cover meets the oil pan and the block, it has yet to leak a quart but it makes a hella mess on the side of my car. what would be the bast way to fix it until i ge a chance to pull the engine and replace the gasket. i heard of this stuff that is like quiksteel that uses oil as the activating agent, i think its called type-O something? anyone know what im talking about or have any ideas?
*Eric*
breakthelawinaz is offline
Old 06-21-2004, 12:24 PM
Advanced Tech Moderator
kmook's Avatar
This would be best asked in a gen spacific forum. Transfering, thanks.
kmook is offline
Old 06-21-2004, 12:36 PM
sorry about that, i realized it was in the super technical section after i posted that i apologize for that...
*Eric*
Old 06-21-2004, 05:13 PM
Rice Killer87's Avatar
if u can get to it,try putting some silicone on it.
Rice Killer87 is offline
Old 06-21-2004, 06:12 PM
lordmetalz28's Avatar
lucas oil stabalizer, slows ( slows) slows!!!!!! most oil leaks, wont stop it completley but better then nothing
lordmetalz28 is offline
Old 06-21-2004, 06:15 PM
oh and bye the way are u home from school as where i can buy your hood
Old 06-22-2004, 11:39 AM
izzyz28's Avatar
I would recommend just removing the timing cover with the engine in the vehicle. It's should only take a couple of hours to pull the cover off and fix it properly. I could switch cams in my 85 Firebird and have it on the road in six hours. It's really not that bad. Until then I would recommend cleaning the area with brake cleaner and using some Mopar RTV. It's good stuff.
Good luck!
izzyz28 is offline
Magenta_Hearts
03-29-2017 08:54 PM
kallcium
V6 Tech
10-07-2015 03:39 PM
BigWil
03-29-2015 12:24 PM
artic94
01-17-2015 11:19 AM
Quick Reply: what is the best way to fix an oil leak?
