washing engine
washing engine
I have an 88 camaro with a carburated 350. To wash the engine, (in a manual car wash) is there anything i should cover or keep from getting wet. If anybody could tell me what they are, if there's any, that'd be great. Thanks for any information.
try not to spray the filter or the distributer, it`s best to have the car running so when your spraying it and the engine starts to die you know to stop spraying it till it starts running smooth again.because if you get water in the intake it might be a basturd to start again.
I'll go against the others and say leave the engine off. Running voltage through wiring with a lot of water is a no-no. Even the nearly 2 decade old weatherpack connectors probably won't keep water out.
If you've got a snorkel type aircleaner just cover the distributor in plastic and avoid spraying into the snorkel. Avoid the headlight area as much as possible as the headlight connectors do not have weatherpack connectors on them.
BTW - spraying on some degreaser with the engine hot and letting it sit for a minute before spraying will do wonders...
If for some reason you suspect water got into the intake, pull the plugs and crank the engine a few times to purge all the water.
Good stuff!
Awhile back I spilled some oil on my drive-way,so while shopping at Wally-world I picked up some drive-way cleaner called REVIVE ,and tried it out,this stuff WORKED ,and it's biodegradable too. Reading the label (fine print,hehe!) says it will clean your engine too! Ok I went out to the ol daily ,and squirt,squirt ,and went back inside about two hours later (opps only suppose to be like 15mins.)ran the hose over it and WOW,I was impressed it took off even the caked on stuff (and a little paint in places),but that was my fault I did leave it on too long. Big plus is it was the cheapest stuff they had,I'm sold!
Originally posted by robvas
Use a few cans of GUNK foaming degreaser
Cover the carb and distributor up with plastic bags.
Cover the alternator, too
Originally posted by Sitting Bull
But be prepared to live with the stench of diesel fuel for a couple weeks!
i used purple power, (that shut works awesome!) and a pressure washer, but now i have this thing where i throw a O2 code everyday for about 5 min on the way to school...
BTW: my car is tpi so i didnt have the intake issue but i did cover coil and dist. with a plastic bag...
*Eric*
*Eric*
Caps94ZODG
22
07-30-2002 08:45 AM
maroman57
12
08-01-2001 11:21 PM
Maroon95Z
07-30-2001 09:01 PM
